Retrieve observed events
GET /support/ems/events
Retrieves a collection of observed events.
Related ONTAP commands
event log show
Learn more
source |
string |
query |
False |
Filter by source |
parameters.name |
string |
query |
False |
Filter by parameters.name |
parameters.value |
string |
query |
False |
Filter by parameters.value |
index |
integer |
query |
False |
Filter by index |
message.severity |
string |
query |
False |
Filter by message.severity |
message.name |
string |
query |
False |
Filter by message.name |
time |
string |
query |
False |
Filter by time |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
log_message |
string |
query |
False |
Filter by log_message |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"index": 1,
"log_message": "string",
"message": {
"name": "callhome.spares.low",
"severity": "emergency"
"node": {
"name": "node1",
"parameters": [
"name": "numOps",
"value": 123
"source": "string",
"time": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
message
_links |
name |
string |
Message name of the event. Returned by default. |
severity |
string |
Severity of the event. Returned by default. |
node
_links |
name |
string |
uuid |
string |
parameters
name |
string |
Name of parameter |
value |
string |
Value of parameter |
records
_links |
index |
integer |
Index of the event. Returned by default. |
log_message |
string |
A formatted text string populated with parameter details. Returned by default. |
message |
node |
parameters |
array[parameters] |
A list of parameters provided with the EMS event. |
source |
string |
Source |
time |
string |
Timestamp of the event. Returned by default. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
