REST API reference
Update an FPolicy persistent store configuration for an SVM
Updates the FPolicy persistent store configuration for a specific SVM to modify its settings or change the associated volume. Use this endpoint when you need to adjust the configuration or migrate to a different storage volume.
HTTP method and endpoint
PATCH /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced in
ONTAP 9.14
Usage notes
Updates a specific FPolicy Persistent Store configuration for an SVM.
Important notes:
  • If the volume exists, it is set to the size specified and the snapshot policy is set to "none". Otherwise, a new volume is created.
  • The autosize parameter is not available in PATCH operations for this endpoint, use the the "autosize" parameter in PATCH for the "/storage/volumes/{uuid}" endpoint instead.
  • When the Persistent Store is updated with a new volume, the previous volume is not automatically deleted. An option is provided to delete the previous volume.
  • fpolicy persistent-store modify
name
string
path
True
delete_volume
boolean
query
False
Delete the previous volume of a Persistent Store if a new volume is provided.
  • Introduced in: 9.15
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
size
integer
The size of the Persistent Store volume, in bytes.
svm
svm
volume
string
The specified volume to store the events for the FPolicy Persistent Store.
Example request
  "size": "100M",
  "svm": {
    "uuid": "string"
  "volume": "psvol"
Status: 200, Ok
Status: Default
Error Code Description
9765053
Volume mentioned does not exist in the SVM
9765056
Specified Persistent Store name does not exist in the SVM
9765069
Volume is not a FlexVol volume. Only FlexVol volumes are supported for this operation.
9765070
Cannot update a Persistent Store volume when it is part of an enabled policy
9765072
Volume is not of type RW. Only volumes of type RW are supported.
9765074
Size is a required parameter for the creation of the Persistent Store.
9765077
The SVM is not associated with any aggregates.
524849
Attribute cannot be modified for the target volume because of the specified reason.
917533
The target volume is not eligible for modification due to certain constraints, such as the volume being offline or currently engaged in a volume move operation.
917826
Volume minimum autosize must be greater than zero.
918647
The designated size exceeds the maximum available capacity of the intended volume.
917534
The value specified for the field \"-size\" is too small. Update the field \"-size\" with the minimum size allowed and retry the operation.
svm
uuid
string
SVM UUID
fpolicy_persistent_store
The information that an FPolicy process needs in order to configure a Persistent Store.
size
integer
svm
svm
volume
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
