Update an FPolicy persistent store configuration for an SVM
PATCH /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced In: 9.14
Updates a specific FPolicy Persistent Store configuration for an SVM.
Important notes:
If the volume exists, it is set to the size specified and the snapshot policy is set to "none". Otherwise, a new volume is created.
The autosize parameter is not available in PATCH operations for this endpoint, use the the "autosize" parameter in PATCH for the "/storage/volumes/{uuid}" endpoint instead.
When the Persistent Store is updated with a new volume, the previous volume is not automatically deleted. An option is provided to delete the previous volume.
Related ONTAP commands
fpolicy persistent-store modify
name |
string |
path |
True |
delete_volume |
boolean |
query |
False |
Delete the previous volume of a Persistent Store if a new volume is provided.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
size |
integer |
The size of the Persistent Store volume, in bytes. |
svm |
volume |
string |
The specified volume to store the events for the FPolicy Persistent Store. |
Example request
"size": "100M",
"svm": {
"uuid": "string"
"volume": "psvol"
Status: 200, Ok
Status: Default
| Error Code | Description |
9765053 |
Volume mentioned does not exist in the SVM |
9765056 |
Specified Persistent Store name does not exist in the SVM |
9765069 |
Volume is not a FlexVol volume. Only FlexVol volumes are supported for this operation. |
9765070 |
Cannot update a Persistent Store volume when it is part of an enabled policy |
9765072 |
Volume is not of type RW. Only volumes of type RW are supported. |
9765074 |
Size is a required parameter for the creation of the Persistent Store. |
9765077 |
The SVM is not associated with any aggregates. |
524849 |
Attribute cannot be modified for the target volume because of the specified reason. |
917533 |
The target volume is not eligible for modification due to certain constraints, such as the volume being offline or currently engaged in a volume move operation. |
917826 |
Volume minimum autosize must be greater than zero. |
918647 |
The designated size exceeds the maximum available capacity of the intended volume. |
917534 |
The value specified for the field \"-size\" is too small. Update the field \"-size\" with the minimum size allowed and retry the operation. |
svm
uuid |
string |
SVM UUID |
fpolicy_persistent_store
The information that an FPolicy process needs in order to configure a Persistent Store.
size |
integer |
svm |
volume |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
