REST API reference
Create an S3 bucket snapshot
POST /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/snapshots
Introduced In: 9.16
Creates an S3 bucket snapshot.
Required properties
  • name - Name of the S3 bucket snapshot to be created.
  • vserver object-store-server bucket snapshot create
s3_bucket.uuid
string
path
True
Unique identifier of a bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
bucket_uuid
string
The unique identifier of the bucket.
create_time
string
Creation time of the snapshot. It is the storage unit access time when the snapshot was created.
name
string
The name of the snapshot. Snapshot names must start with a lowercase letter, a number, or a hyphen, must end with a lowercase letter or a number, and cannot exceed 30 characters.
svm
svm
Specifies the name of the SVM where this bucket exists.
uuid
string
The UUID of the snapshot in the bucket that uniquely identifies the snapshot in that bucket.
Example request
  "bucket_uuid": "2aec8270-58e3-11ef-861e-005056ae1130",
  "create_time": "2024-08-21 20:18:04 -0400",
  "name": "snap1",
  "svm": {
    "name": "svm1",
  "uuid": "522b29a1-3b26-11e9-bd58-0050568ea321"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error code Message
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92406249
"Failed to create S3 bucket snapshot "{snapshot name}" for S3 bucket "{bucket name}" in SVM "{svm name}". Reason: {Reason for failure} ";
string
svm
name
string
uuid
string
s3_bucket_snapshot
Information about an S3 bucket snapshot.
bucket_uuid
string
create_time
string
name
string
svm
svm
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
