Create a FlexCache volume in the cluster
Creates a FlexCache volume within the cluster to efficiently manage and optimize data access. This operation is especially useful for improving performance and reducing latency in data retrieval across distributed environments.
HTTP method and endpoint
POST /storage/flexcache/flexcaches
Introduced in
ONTAP 9.6
Usage notes
Creates a FlexCache in the cluster.
Required properties
name- Name of FlexCache volume. -
origins.volume.name- Name of the origin volume. This volume can only be identified by its name, not by its UUID. -
origins.svm.name- Name of origin Vserver. -
svm.nameorsvm.uuid- Name or UUID of Vserver where FlexCache will be created.
Recommended optional properties
path- Path to mount the FlexCache volume -
prepopulate.dir_paths- List of directory-paths to be prepopulated for the FlexCache volume. -
prepopulate.exclude_dir_paths- List of directory-paths to be excluded from prepopulation for he FlexCache volume.
Default property values
If not specified in POST, the following default property values are assigned:
size- 10% of origin volume size or 1GB per constituent, whichever is greater. -
guarantee.type- none. FlexCache is thin provisioned by default. -
constituents_per_aggregate- 4 if aggregates.name or aggregates.uuid is used. -
use_tiered_aggregate- false if aggr-list is not used. This property is only used when auto-provisioning a FlexCache volume. -
is_disconnected_mode_off_for_locks- false. This property specifies if the origin will honor the cache side locks when doing the lock checks in the disconnected mode. -
dr_cache- false if FlexCache is not a DR cache. This property is used to create a DR FlexCache. -
global_file_locking_enabled- false. This property specifies whether global file locking is enabled on the FlexCache volume. -
writeback.enabled- false. This property specifies whether writeback is enabled for the FlexCache volume. -
relative_size.enabled- false. This property specifies whether the relative sizing is enabled for the FlexCache volume. -
relative_size.percentage- 10. This property specifies the percent size FlexCache volume should have relative to the total size of the origin volume. -
override_encryption- false. If true, this property is used to create a plaintext FlexCache volume for an encrypted origin volume. -
atime_scrub.enabled- false. This property specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. -
atime_scrub.period- 30. This property specifies the atime duration in days after which the file can be scrubbed from the FlexCache volume if it stays unused beyond the duration. -
cifs_change_notify.enabled- false. This property specifies whether a CIFS change notification is enabled for the FlexCache volume.
Related ONTAP commands
volume flexcache create -
volume flexcache prepopulate start
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
aggregates |
array[aggregates] |
atime_scrub |
FlexCache volume atime-based scrub |
cifs_change_notify |
Notifies that a change has been made to the FlexCache volume CIFS. |
constituents_per_aggregate |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
dr_cache |
boolean |
If set to true, a DR cache is created. |
global_file_locking_enabled |
boolean |
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, the "is_disconnected_mode_off_for_locks" flag is always set to "true". |
guarantee |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
override_encryption |
boolean |
If set to true, a plaintext FlexCache volume for an encrypted origin volume is created. |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
prepopulate |
FlexCache prepopulate |
relative_size |
FlexCache Relative Size |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
use_tiered_aggregate |
boolean |
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume. |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
writeback |
FlexCache Writeback |
Example request
"aggregates": [
"name": "aggr1",
"constituents_per_aggregate": 1,
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 15:00:00 -0400",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"prepopulate": {
"dir_paths": [
"/dir1"
"exclude_dir_paths": [
"/dir1/dir2"
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
11 |
Provided value is smaller than the required minimum flexvolume size. |
262186 |
Invalid combination with field "aggregates". |
917937 |
The root path "/" is an invalid value for the field "path". |
918723 |
Aggregate value cannot be used to create a volume on this platform. |
66846735 |
The peer state of the relationship is not peered or the FlexCache application is not supported by the relationship |
66846762 |
The origin volume in the SVM is offline |
66846767 |
Volume does not exist in SVM. |
66846867 |
Global file locking (GFL) mode is already disabled for origin of a FlexCache volume in SVM. Enabling GFL is only supported when the first FlexCache volume is created for an origin. Set is_global_file_locking_enabled" to "false". |
66846768 |
Volume already exists in SVM. |
66846863 |
The "preserve-msid" parameter is not supported when creating the FlexCache volume in the same SVM as the origin of a FlexCache volume |
66846870 |
Either the SVM name or origin volume name is missing |
66846871 |
Constituents per aggregate are specified but aggregate name is missing |
66846872 |
More than one origin volume is specified |
66846873 |
The specified SVM UUID is incorrect for the specified SVM name |
66846874 |
The specified name and SVM uuid refer to different aggregates. |
66846875 |
The specified aggregate name does not exist |
66846876 |
The specified SVM does not exist or is not peered |
66846877 |
The specified origin SVM name is of zero length |
66846878 |
The specified SVM UUID is invalid |
66846998 |
Failed to modify the "relative_size_percentage" property of volume in SVM because the "relative_size_enabled" property is false. |
66846730 |
Failed to create a FlexCache volume |
66846760 |
The specified SVM is not a data Vserver |
66846787 |
The specified aggregate is a SnapLock aggregate |
66846812 |
The specified aggregate is a Composite aggregate |
66846812 |
The specified junction path is under a FlexCache volume |
66846834 |
FlexCache encryption requires a cluster version of 9.6 or higher |
66846835 |
A volume encryption license is not found |
66847013 |
Creating a FlexCache volume with override-encryption property set to true requires an effective cluster version of 9.14.0 or later on both origin and cache clusters |
66846844 |
An object store server volume cannot be the origin of a FlexCache volume |
66846902 |
FlexCache is not supported on an All SAN Array system. |
66846915 |
The "use_tiered_aggregate" option is only supported when auto provisioning the FlexCache volume. |
66847026 |
Failed to enable the atime-scrub-enabled property for the FlexCache volume because the atime-update-property is false |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
atime_scrub
enabled |
boolean |
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value. |
period |
integer |
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day. |
cifs_change_notify
enabled |
boolean |
Specifies whether a CIFS change notification is enabled for the FlexCache volume. |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
name |
string |
uuid |
string |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster management IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
prepopulate
dir_paths |
array[string] |
exclude_dir_paths |
array[string] |
recurse |
boolean |
Specifies whether or not the prepopulate action should search through the |
relative_size
enabled |
boolean |
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume. |
percentage |
integer |
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled. |
svm
FlexCache SVM
name |
string |
uuid |
string |
writeback
FlexCache Writeback
enabled |
boolean |
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume. |
flexcache
Defines the cache endpoint of FlexCache.
aggregates |
array[aggregates] |
atime_scrub |
integer |
dr_cache |
boolean |
boolean |
guarantee |
name |
string |
FlexCache name |
origins |
boolean |
path |
string |
prepopulate |
relative_size |
size |
integer |
svm |
FlexCache SVM |
boolean |
uuid |
string |
writeback |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
