REST API reference
Create a FlexCache volume in the cluster
POST /storage/flexcache/flexcaches
Introduced In: 9.6
Creates a FlexCache in the cluster.
Required properties
  • name - Name of FlexCache volume.
  • origins.volume.name - Name of the origin volume. This volume can only be identified by its name, not by its UUID.
  • origins.svm.name - Name of origin Vserver.
  • svm.name or svm.uuid - Name or UUID of Vserver where FlexCache will be created.
  • path - Path to mount the FlexCache volume
  • prepopulate.dir_paths - List of directory-paths to be prepopulated for the FlexCache volume.
  • prepopulate.exclude_dir_paths - List of directory-paths to be excluded from prepopulation for the FlexCache volume.
Default property values
If not specified in POST, the following default property values are assigned:
  • size - 10% of origin volume size or 1GB per constituent, whichever is greater.
  • guarantee.type - none. FlexCache is thin provisioned by default.
  • constituents_per_aggregate - 4 if aggregates.name or aggregates.uuid is used.
  • use_tiered_aggregate - false if aggr-list is not used. This property is only used when auto-provisioning a FlexCache volume.
  • is_disconnected_mode_off_for_locks - false. This property specifies if the origin will honor the cache side locks when doing the lock checks in the disconnected mode.
  • dr_cache - false if FlexCache is not a DR cache. This property is used to create a DR FlexCache.
  • global_file_locking_enabled - false. This property specifies whether global file locking is enabled on the FlexCache volume.
  • writeback.enabled - false. This property specifies whether writeback is enabled for the FlexCache volume.
  • relative_size.enabled - false. This property specifies whether the relative sizing is enabled for the FlexCache volume.
  • relative_size.percentage - 10. This property specifies the percent size FlexCache volume should have relative to the total size of the origin volume.
  • override_encryption - false. If true, this property is used to create a plaintext FlexCache volume for an encrypted origin volume.
  • atime_scrub.enabled - false. This property specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume.
  • atime_scrub.period - 30. This property specifies the atime duration in days after which the file can be scrubbed from the FlexCache volume if it stays unused beyond the duration.
  • nfsv4.enabled - false. This property specifies whether NFSv4 is enabled for the FlexCache volume.
  • cifs.enabled - false. This property specifies whether CIFS is enabled for the FlexCache volume.
  • s3.enabled - false. This property specifies whether S3 is enabled for the FlexCache volume.
  • cifs_change_notify.enabled - false. This property specifies whether a CIFS change notification is enabled for the FlexCache volume.
  • volume flexcache create
  • volume flexcache prepopulate start
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
aggregates
array[aggregates]
atime_scrub
atime_scrub
FlexCache volume atime-based scrub
cifs
cifs
FlexCache CIFS
cifs_change_notify
cifs_change_notify
Notifies that a change has been made to the FlexCache volume CIFS.
integer
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned.
dr_cache
boolean
If set to true, a DR cache is created.
boolean
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, the "is_disconnected_mode_off_for_locks" flag is always set to "true".
guarantee
guarantee
name
string
FlexCache name
nfsv4
nfsv4
FlexCache NFSv4
origins
array[flexcache_relationship]
override_encryption
boolean
If set to true, a plaintext FlexCache volume for an encrypted origin volume is created.
path
string
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path.
prepopulate
prepopulate
FlexCache prepopulate
relative_size
relative_size
FlexCache Relative Size
s3
s3
Flexcache S3
size
integer
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB.
svm
svm
FlexCache SVM
boolean
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume.
uuid
string
FlexCache UUID. Unique identifier for the FlexCache.
writeback
writeback
FlexCache Writeback
Example request
  "aggregates": [
      "name": "aggr1",
  "constituents_per_aggregate": 1,
  "guarantee": {
    "type": "string"
  "name": "vol1",
  "origins": [
      "cluster": {
        "name": "cluster1",
      "create_time": "2018-06-04 19:00:00 +0000",
      "ip_address": "10.10.10.7",
      "size": 0,
      "state": "string",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
  "path": "/user/my_fc",
  "prepopulate": {
    "dir_paths": [
      "/dir1"
    "exclude_dir_paths": [
      "/dir1/dir2"
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
11
Provided value is smaller than the required minimum flexvolume size.
262186
Invalid combination with field "aggregates".
917937
The root path "/" is an invalid value for the field "path".
918723
Aggregate value cannot be used to create a volume on this platform.
66846735
The peer state of the relationship is not peered or the FlexCache application is not supported by the relationship
66846762
The origin volume in the SVM is offline
66846767
Volume does not exist in SVM.
66846867
Global file locking (GFL) mode is already disabled for origin of a FlexCache volume in SVM. Enabling GFL is only supported when the first FlexCache volume is created for an origin. Set is_global_file_locking_enabled" to "false".
66846768
Volume already exists in SVM.
66846863
The "preserve-msid" parameter is not supported when creating the FlexCache volume in the same SVM as the origin of a FlexCache volume
66846870
Either the SVM name or origin volume name is missing
66846871
Constituents per aggregate are specified but aggregate name is missing
66846872
More than one origin volume is specified
66846873
The specified SVM UUID is incorrect for the specified SVM name
66846874
The specified name and SVM uuid refer to different aggregates.
66846875
The specified aggregate name does not exist
66846876
The specified SVM does not exist or is not peered
66846877
The specified origin SVM name is of zero length
66846878
The specified SVM UUID is invalid
66846998
Failed to modify the "relative_size_percentage" property of volume in SVM because the "relative_size_enabled" property is false.
66846730
Failed to create a FlexCache volume
66846760
The specified SVM is not a data Vserver
66846787
The specified aggregate is a SnapLock aggregate
66846812
The specified aggregate is a Composite aggregate
66846812
The specified junction path is under a FlexCache volume
66846834
FlexCache encryption requires a cluster version of 9.6 or higher
66846835
A volume encryption license is not found
66847013
Creating a FlexCache volume with override-encryption property set to true requires an effective cluster version of 9.14.0 or later on both origin and cache clusters
66846844
An object store server volume cannot be the origin of a FlexCache volume
66846902
FlexCache is not supported on an All SAN Array system.
66846915
The "use_tiered_aggregate" option is only supported when auto provisioning the FlexCache volume.
66847026
Failed to enable the atime-scrub-enabled property for the FlexCache volume because the atime-update-property is false
string
aggregates
Aggregate
name
string
uuid
string
atime_scrub
enabled
boolean
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value.
period
integer
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day.
cifs
FlexCache CIFS
enabled
boolean
Specifies whether CIFS access is enabled on the FlexCache volume.
cifs_change_notify
enabled
boolean
Specifies whether a CIFS change notification is enabled for the FlexCache volume.
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
nfsv4
FlexCache NFSv4
enabled
boolean
Specifies whether NFSv4 access is enabled on the FlexCache volume.
cluster
name
string
uuid
string
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster management IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
svm
svm
volume
volume
prepopulate
dir_paths
array[string]
exclude_dir_paths
array[string]
recurse
boolean
Specifies whether or not the prepopulate action should search through the dir_paths recursively. If not set, the default value true is used.
relative_size
enabled
boolean
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume.
percentage
integer
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled.
s3
Flexcache S3
enabled
boolean
Indicates whether S3 access is enabled on the Flexcache volume.
svm
FlexCache SVM
name
string
uuid
string
writeback
FlexCache Writeback
enabled
boolean
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume.
flexcache
Defines the cache endpoint of FlexCache.
aggregates
array[aggregates]
atime_scrub
atime_scrub
cifs
cifs
FlexCache CIFS
cifs_change_notify
cifs_change_notify
integer
dr_cache
boolean
boolean
guarantee
guarantee
name
string
FlexCache name
nfsv4
nfsv4
FlexCache NFSv4
origins
override_encryption
boolean
path
string
prepopulate
prepopulate
relative_size
relative_size
s3
s3
Flexcache S3
size
integer
svm
svm
FlexCache SVM
boolean
uuid
string
writeback
writeback
FlexCache Writeback
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
