Create a FlexCache volume in the cluster
Creates a FlexCache volume in the cluster to optimize data access and improve performance by caching frequently accessed data from an origin volume. This is useful when you need to reduce latency and improve throughput in environments with heavy read operations.
HTTP method and endpoint
POST /storage/flexcache/flexcaches
Introduced in
ONTAP 9.6
Usage notes
Creates a FlexCache in the cluster.
Required properties
name- Name of FlexCache volume. -
origins.volume.nameororigins.volume.uuid- Name or UUID of origin volume. -
origins.svm.name- Name of origin Vserver. -
svm.nameorsvm.uuid- Name or UUID of Vserver where FlexCache will be created.
Recommended optional properties
path- Path to mount the FlexCache volume -
prepopulate.dir_paths- List of directory-paths to be prepopulated for the FlexCache volume. -
prepopulate.exclude_dir_paths- List of directory-paths to be excluded from prepopulation for he FlexCache volume.
Default property values
If not specified in POST, the following default property values are assigned:
size- 10% of origin volume size or 1GB per constituent, whichever is greater. -
guarantee.type- none. FlexCache is thin provisioned by default. -
constituents_per_aggregate- 4 if aggregates.name or aggregates.uuid is used. -
use_tiered_aggregate- false if aggr-list is not used. This property is only used when auto-provisioning a FlexCache volume. -
is_disconnected_mode_off_for_locks- false. This property specifies if the origin will honor the cache side locks when doing the lock checks in the disconnected mode. -
dr_cache- false if FlexCache is not a DR cache. This property is used to create a DR FlexCache. -
global_file_locking_enabled- false. This property specifies whether global file locking is enabled on the FlexCache volume.
Related ONTAP commands
volume flexcache create -
volume flexcache prepopulate start
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
aggregates |
array[aggregates] |
constituents_per_aggregate |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
dr_cache |
boolean |
If set to true, a DR cache is created. |
global_file_locking_enabled |
boolean |
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. |
guarantee |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
prepopulate |
FlexCache prepopulate |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
use_tiered_aggregate |
boolean |
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume. |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
Example request
"aggregates": [
"name": "aggr1",
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04T19:00:00Z",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"prepopulate": {
"dir_paths": [
"/dir1"
"exclude_dir_paths": [
"/dir1/dir2"
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846870 |
Either the SVM name or origin volume name is missing |
66846871 |
Constituents per aggregate are specified but aggregate name is missing |
66846872 |
More than one origin volume is specified |
66846873 |
The specified SVM UUID is incorrect for the specified SVM name |
66846874 |
The specified aggregate UUID is incorrect for the specified aggregate name |
66846875 |
The specified aggregate name does not exist |
66846876 |
The specified SVM does not exist or is not peered |
66846877 |
The specified origin SVM name is of zero length |
66846878 |
The specified SVM UUID is invalid |
66846730 |
Failed to create a FlexCache volume |
66846760 |
The specified SVM is not a data Vserver |
66846787 |
The specified aggregate is a SnapLock aggregate |
66846812 |
The specified aggregate is a Composite aggregate |
66846812 |
The specified junction path is under a FlexCache volume |
66846834 |
FlexCache encryption requires a cluster version of 9.6 or higher |
66846835 |
A volume encryption license is not found |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
prepopulate
dir_paths |
array[string] |
exclude_dir_paths |
array[string] |
recurse |
boolean |
Specifies whether or not the prepopulate action should search through the directory-path recursively. If not set, the default value "true" is used. |
svm
FlexCache SVM
name |
string |
uuid |
string |
flexcache
Defines the cache endpoint of FlexCache.
aggregates |
array[aggregates] |
integer |
dr_cache |
boolean |
boolean |
guarantee |
name |
string |
FlexCache name |
origins |
path |
string |
prepopulate |
size |
integer |
svm |
FlexCache SVM |
boolean |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
