Cluster software endpoint overview
Overview
ONTAP cluster software API retrieves and displays relevant information about the software profile, software packages collection, and software history collection. The API retrieves the information about all software packages present in the cluster, or specific software package.
The POST request provides the ability to download a software package from an HTTP or FTP server. The PATCH request provides the option to upgrade the cluster software version. The client can validate the package before triggering the update by selecting the validate_only field. Setting the version field triggers the installation of the package in the cluster. The client can pause, resume, or cancel any ongoing software upgrade by selecting action. The DELETE request can remove a specific software package present in the cluster.
Retrieving software profile information
The following example shows how to retrieve software profile information. The client can check the validation results after selecting validate_only field. Upgrade progress information is available after an upgrade has started.
# The API:
/api/cluster/software
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software?return_timeout=15" -H "accept: application/hal+json"
# The response:
"validation_results": [
"update_check": "NFS mounts",
"status": "warning",
"message": [
"code": 166,
"message": "Use NFS hard mounts, if possible.",
"arguments": [
"string"
"action": [
"code": 166,
"arguments": [
"string"
"version": "9.5.0",
"pending_version": "9.6.0",
"nodes": [
"node": "sti70-vsim-ucs165n",
"version": "9.5.0"
"metrocluster": {
"progress_summary": "Update paused by user",
"progress_details": "Installing Data ONTAP software image on cluster \"sti70-vsim-ucs165n_siteA\".",
"clusters": [
"name": "sti70-vsim-ucs165n_siteA",
"uuid": "720f046c-4b13-11e9-9c34-005056ac5626",
"estimated_duration": 3480,
"elapsed_duration": 0,
"state": "waiting"
"state": "in_progress",
"start_time": "2018-05-21T09:53:04+05:30",
"end_time": "2018-05-21T11:53:04+05:30",
"estimated_time": 5220,
"elapsed_time": 2140,
"update_details": [
"phase": "Data ONTAP updates",
"estimated_duration": 4620,
"elapsed_duration": 29,
"node": {
"name": "sti70-vsim-ucs165n"
"status_details": [
"name": "do-download-job",
"state": "completed",
"message": "Image update complete",
"action": "",
"node": {
"href": "/api/cluster/software/"
Upgrading the software version
The following example shows how to upgrade cluster software. Setting the version field triggers the installation of the package. The client can select the validate_only field to validate the package before the installation starts. Setting skip_warning as true ignores the validation warning before the installation starts. Setting the action field performs a pause, resume, or `cancel' to an ongoing upgrade. An upgrade can only be resumed if it is in the paused state.
The client can start the upgrade process at the cluster-level. There are no options available to start the upgrade for a specific node or HA pairs.
1. Validating the package and verifying the validation results
The following example shows how to validate a cluster software package. The client has to validate the package before the software upgrade. The client must set the validate_only field to true to start the validation. The client can check for validation results in the GET /cluster/software endpoint.
# The API:
# The call:
curl -X PATCH "https://<mgmt_ip>/api/cluster/software?validate_only=true" -H "accept: application/json" -H "Content-Type: application/hal+json" -d '{ "version": "9.5.0"}'
# The response:
"job": {
"uuid": "f587d316-5feb-11e8-b0e0-005056956dfc",
"href": "/api/cluster/jobs/f587d316-5feb-11e8-b0e0-005056956dfc"
The call to validate the software cluster version returns the job UUID, including a HAL link to retrieve details about the job. The job object includes a state and a message to indicate the progress of the job. When the job is complete and the application has been fully created, the message indicates success and the state field of the job is set to success.
# The API:
/api/cluster/jobs/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/jobs/f587d316-5feb-11e8-b0e0-005056956dfc" -H "accept: application/hal+json"
# The response:
"description": "PATCH /api/cluster/software",
"state": "success",
"message": "success",
"code": 0,
The client can check for validation results in the GET /cluster/software endpoint. The following example shows how to check the validation warnings and errors after setting the validate_only field to true.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software" -H "accept: application/hal+json"
# The response:
"version": "9.7.0",
"update_check": "High Availability status",
"status": "error",
"message": "Cluster HA is not configured in the cluster. Storage failover is not enabled on node \"node1\", \"node2\".",
"action": "Check cluster HA configuration. Check storage failover status."
"update_check": "Manual checks",
"message": "Manual validation checks need to be performed. Refer to the Upgrade Advisor Plan or \"Performing manual checks before an automated cluster upgrade\" section in the \"Clustered Data ONTAP Upgrade Express Guide\" for the remaining validation checks that need to be performed before update. Failing to do so can result in an update failure or an I/O disruption.",
"action": "Refer to the Upgrade Advisor Plan or \"Performing manual checks before an automated cluster upgrade\" section in the \"Clustered Data ONTAP Upgrade Express Guide\" for the remaining validation checks that need to be performed before update."
"nodes": [
"node": "node1",
"version": "9.7.0"
"node": "node2",
"version": "9.7.0"
"state": "failed",
"elapsed_duration": 56,
"estimated_duration": 600,
"href": "/api/cluster/software"
2. Updating the cluster
The following example shows how to initiate a cluster software upgrade. The client must validate the package before the software upgrade starts. The client must set the skip_warnings field to true in order to skip any validation warnings and start the software package upgrade.
# The API:
# The call:
curl -X PATCH "https://<mgmt_ip>/api/cluster/software?skip_warnings=true" -H "accept: application/json" -H "Content-Type: application/hal+json" -d '{ "version": "9.5.0"}'
# The response:
"job": {
The call to update the software cluster version returns the job UUID, including a HAL link to retrieve details about the job. The job object includes a state and a message to indicate the progress of the job. When the job is complete and the application has been fully created, the message indicates success and the state field of the job is set to success.
# The API:
# The call:
# The response:
"state": "success",
"code": 0,
The client can check the update progress information in the GET /cluster/software endpoint. The following example shows how to check the progress of an update after setting the skip_warnings field to true.
# The API:
# The call:
# The response:
"version": "9.7.0",
"nodes": [
"node": "node1",
"version": "9.7.0"
"node": "node2",
"version": "9.7.0"
"pending_version": "9.7.0",
"elapsed_duration": 63,
"estimated_duration": 5220,
"status_details": [
"status": "running",
"message": "",
"action": "",
"start_time": "2019-01-14T23:12:14+05:30",
"end_time": "2019-01-14T23:12:14+05:30",
"node": {
"name": "node1"
"message": "",
"action": "",
"node": {
"name": "node2"
"update_details": [
"status": "in-progress",
"elapsed_duration": 10,
"node": {
"name": "node1"
"node": {
"name": "node2"
3. Pausing/resuming/cancelling the upgrade
The following example shows how to pause an ongoing cluster software package upgrade. The client must set the action field to pause, resume, or cancel which pauses, resumes or cancels the upgrade respectively. Not all update operations support these actions. An update can only be resumed if it is in the paused state.
# The API:
# The call:
curl -X PATCH "https://<mgmt_ip>/api/cluster/software?action=pause" -H "accept: application/json" -H "Content-Type: application/hal+json" -d '{ "version": "9.5.0"}'
# The response:
"job": {
# The API:
# The call:
# The response:
"state": "success",
"code": 0,
The client can check the progress of the upgrade in the GET /cluster/software endpoint. The following example shows how to check the progress of the pause upgrade state after setting the action field to pause.
# The API:
# The call:
# The response:
"version": "9.7.0",
"action": "Refer to the Upgrade Advisor Plan or \"Performing manual checks before an automated cluster upgrade\" section in the \"Clustered Data ONTAP Upgrade Express Guide\" for the remaining validation checks that need to be performed before update.",
"nodes": [
"node": "node1",
"version": "9.7.0"
"node": "node2",
"version": "9.7.0"
"state": "pause_pending",
"elapsed_duration": 103,
"status_details": [
"message": "Installing Data ONTAP software image.",
"action": "",
"start_time": "2019-01-08T02:54:36+05:30",
"node": {
"name": "node1"
"action": "",
"node": {
"name": "node2"
"update_details": [
"phase": "Pre-update checks",
"status": "completed",
"elapsed_duration": 54,
"node": {
"name": "node1"
"status": "pause-pending",
"elapsed_duration": 49,
"node": {
"name": "node2"
Downloading the software package
The following example shows how to download the software package from an HTTP or FTP server. The client provides the url, username, and password to start the download of the software package to the cluster.
# The API:
/api/cluster/software/download
# The call:
curl -X POST "https://<mgmt-ip>/api/cluster/software/download?return_timeout=0" -H "accept: application/json" -H "Content-Type: application/hal+json" -d '{ "url": "http://nbsweb.eng.btc.netapp.in/~suvadipd/99/image1.tgz", "username": "admin", "password": "*********"}'
# The response:
"job": {
The call to download the software package returns the job UUID, including a HAL link to retrieve details about the job. The job object includes a state and a message to indicate the progress of the job. When the job is complete and the application has been fully created, the message indicates success and the job state field is set to success.
# The API:
# The call:
# The response:
"description": "POST /api/cluster/software/download",
"state": "success",
"code": 0,
Retrieving cluster software packages information
The following example shows how to retrieve the ONTAP software packages in a cluster.
# The API:
/api/cluster/software/packages
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software/packages?return_records=true&return_timeout=15" -H "accept: application/hal+json"
# The response:
"records": [
"version": "9.7.0",
"href": "/api/cluster/software/packages/9.7.0"
"version": "9.5.0",
"href": "/api/cluster/software/packages/9.5.0"
"num_records": 2,
"href": "/api/cluster/software/packages"
The following example shows how to retrieve the details of a given cluster software package.
# The API:
/api/cluster/software/packages/{version}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software/packages/9.7.0" -H "accept: application/hal+json"
# The response:
"version": "9.7.0",
"create_time": "2018-05-21T10:06:59+05:30",
Deleting a cluster software package
The following example shows how to delete a package from the cluster. The client needs to provide the package version that they want to delete. The software package delete creates a job to perform the delete operation.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/cluster/software/packages/9.6.0" -H "accept: application/hal+json"
# The response:
"job": {
The call to delete the package returns the job UUID, including a HAL link to retrieve details about the job. The job object includes a state and a message to indicate the progress of the job. When the job is complete and the application has been fully created, the message indicates success and the job state field is set to success.
# The API:
# The call:
# The response:
"description": "DELETE /api/cluster/software/packages/9.6.0",
"state": "success",
"code": 0,
HTTPS error codes
The following is a list of possible error codes that can be returned during a package delete operation.
ONTAP Error Response codes
| Error codes | Description |
10551315 |
Package store is empty |
10551322 |
Error in retrieving package cleanup status |
10551323 |
Error in cleaning up package information on a node |
10551324 |
Error in cleaning up package information on both nodes |
10551325 |
Package does not exist on the system |
10551326 |
Error in deleting older package cleanup tasks |
10551346 |
Package delete failed since a validation is in progress |
10551347 |
Package delete failed since an update is in progress |
10551367 |
A package synchronization is in progress |
10551388 |
Package delete operation timed out |
Retrieving software installation history information
retrieve the software package installation history information.
display specific node level software installation history information.
provide all the attributes by default in response when the self referential link is not present.
# The API:
/api/cluster/software/history
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software/history" -H "accept: application/hal+json"
# The response:
"node": {
"uuid": "58cd3a2b-af63-11e8-8b0d-0050568e7279",
"name": "sti70-vsim-ucs165n",
"href": "/api/cluster/nodes/58cd3a2b-af63-11e8-8b0d-0050568e7279"
"start_time": "2018-09-03T16:18:46+05:30",
"state": "successful"
"from_version": "9.4.0",
"to_version": "9.5.0",
"end_time": "2018-05-21T10:14:51+05:30"
