REST API reference
Deletes a license
learn more
  • [doc /cluster/licensing/licenses/{name}](#docs-cluster-cluster_licensing_licenses_{name})
DELETE /cluster/licensing/licenses/{name}
Deletes a license.
  • system license delete
name
string
path
True
serial_number
string
query
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1115144
Cloud licenses cannot be deleted
1115178
A tier license, that is still in use, cannot be deleted
1115406
Capacity pool licenses cannot be deleted
66846823
A flexcache licenses, that is still in use, cannot be deleted
1115213
License is still in use and cannot be removed
1115137
Cluster license requires a base license to be installed
525028
Error during volume limit check, cannot remove license
525029
Current volume use will exceed limits if license is removed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
