REST API reference
Deletes a schedule
DELETE /cluster/schedules/{uuid}
Deletes a schedule.
uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
459758
Cannot delete a job schedule that is in use. Remove all references to the schedule, and then try to delete again.
459761
Schedule cannot be deleted on this cluster because it is replicated from the remote cluster.
459762
The schedule cannot be deleted because it is a system-level schedule.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
