Deletes the nis domain configuration of an svm nis can be removed as a source from ns-switch if nis is not used for lookups
learn more
doc /name-services/nis](#docs-name-services-name-services_nis)
DELETE /name-services/nis/{svm.uuid}
Deletes the NIS domain configuration of an SVM. NIS can be removed as a source from ns-switch if NIS is not used for lookups.
Related ONTAP commands
vserver services name-service nis-domain delete
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
