REST API reference
Deletes a vlan or lag (ifgrp)
  • network port vlan delete
learn more
  • [doc /network/ethernet/ports](#docs-networking-network_ethernet_ports)
DELETE /network/ethernet/ports/{uuid}
Deletes a VLAN or LAG (ifgrp).
  • network port ifgrp delete
uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966189
Port is the home port or current port of a LIF.
1376858
Port already has a LIF bound.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
