REST API reference
Deletes a specific fpolicy event configuration for an svm a cluster-level fpolicy event configuration cannot be modified for a data svm through rest an fpolicy event that is attached to an fpolicy policy cannot be deleted
learn more
  • [doc /protocols/fpolicy/{svmuuid}/events](#docs-nas-protocols_fpolicy_{svmuuid}_events)
DELETE /protocols/fpolicy/{svm.uuid}/events/{name}
Deletes a specific FPolicy event configuration for an SVM. A cluster-level FPolicy event configuration cannot be modified for a data SVM through REST. An FPolicy event that is attached to an FPolicy policy cannot be deleted.
  • fpolicy policy event delete
svm.uuid
string
path
True
name
string
path
True
Status: 200, Ok
Status: Default
Error Code Description
9764874
The FPolicy event is a cluster event
9764947
The FPolicy event is attached to an FPolicy policy
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
