REST API reference
Remove an NVMe subsystem
DELETE /protocols/nvme/subsystems/{uuid}
Removes an NVMe subsystem.
  • vserver nvme subsystem delete
uuid
string
path
True
allow_delete_while_mapped
boolean
query
False
allow_delete_with_hosts
boolean
query
False
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
72090023
The NVMe subsystem contains one or more mapped namespaces. Use the allow_delete_while_mapped query parameter to delete an NVMe subsystem with mapped NVMe namespaces.
72090024
The NVMe subsystem contains one or more NVMe hosts. Use the allow_delete_with_hosts query parameter to delete an NVMe subsystem with NVMe hosts.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
