Deletes an fc protocol service an fc protocol service must be disabled before it can be deleted
learn more
doc /protocols/san/fcp/services](#docs-san-protocols_san_fcp_services)
DELETE /protocols/san/fcp/services/{svm.uuid}
Deletes an FC Protocol service. An FC Protocol service must be disabled before it can be deleted.
Related ONTAP commands
vserver fcp delete
Learn more
svm.uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
5374083 |
There is no Fibre Channel Protocol service for the specified SVM. |
5373960 |
The Fibre Channel Protocol service cannot be removed while it is enabled. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
