Delete an initiator group
DELETE /protocols/san/igroups/{uuid}
Deletes an initiator group.
Related ONTAP commands
lun igroup delete
Learn more
uuid |
string |
path |
True |
The unique identifier of the initiator group. |
allow_delete_while_mapped |
boolean |
query |
False |
Allow deletion of a mapped initiator group. Deleting a mapped initiator group makes the LUNs to which the initiator group is mapped no longer available. This might cause a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852 |
The initiator group does not exist. |
1254213 |
The initiator group is mapped to one or more LUNs and |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
