REST API reference
Deletes an initiator from an initiator group
learn more
  • [doc /protocols/san/igroups](#docs-san-protocols_san_igroups)
DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Deletes an initiator from an initiator group.
  • lun igroup remove
igroup.uuid
string
path
True
The unique identifier of the initiator group.
name
string
path
True
The initiator name.
allow_delete_while_mapped
boolean
query
False
Allow deletion of an initiator from of a mapped initiator group.
Deleting an initiator from a mapped initiator group makes the LUNs to which the initiator group is mapped no longer available to the initiator. This might cause a disruption in the availability of data.
This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374034
The initiator is not a member of the group.
5374852
The initiator group specified in the URI does not exist.
1254213
The initiator group is mapped to one or more LUNs and allow_delete_while_mapped has not been specified.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
