Deletes specified iscsi credentials
learn more
doc /protocols/san/iscsi/credentials](#docs-san-protocols_san_iscsi_credentials)
DELETE /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Deletes specified iSCSI credentials.
Related ONTAP commands
vserver iscsi security delete
Learn more
svm.uuid |
string |
path |
True |
initiator |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
2621706 |
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5374148 |
The default security credential cannot be deleted for an SVM. |
5374895 |
The iSCSI security credential does not exist on the specified SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
