REST API reference
Deletes an iscsi service an iscsi service must be disabled before it can be deleted
learn more
  • [doc /protocols/san/iscsi/services](#docs-san-protocols_san_iscsi_services)
DELETE /protocols/san/iscsi/services/{svm.uuid}
Deletes an iSCSI service. An iSCSI service must be disabled before it can be deleted.
  • vserver iscsi delete
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
5373960
The iSCSI service is enabled. The iSCSI service must be disabled before it can be deleted.
5374078
The SVM does not have an iSCSI service.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
