Deletes a lun map
learn more
doc /protocols/san/lun-maps](#docs-san-protocols_san_lun-maps)
DELETE /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Deletes a LUN map.
Related ONTAP commands
lun mapping delete
Learn more
lun.uuid |
string |
path |
True |
igroup.uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The LUN was not found. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
