Delete a Vscan scanner-pool configuration
DELETE /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Deletes a Vscan scanner-pool configuration.
Important notes:
The Vscan scanner-pool DELETE endpoint deletes all of the Vscan scanner-pools for a specified SVM.
If a Vscan is enabled, it requires at least one scanner-pool to be in the active state. Therefore, Vscan must be disabled on the specified SVM so that all of the scanner-pools configured on that SVM can be deleted.
Related ONTAP commands
vserver vscan scanner-pool delete
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
name |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027070 |
Attempting to delete a scanner-pool but it is the only active scanner-pool for a Vscan enabled on the SVM |
10027064 |
Attempting to delete a scanner-pool with a data SVM which was created with an administrative SVM |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
