Delete a primary key server
DELETE /security/key-managers/{uuid}/key-servers/{server}
Deletes a key server.
Related ONTAP commands
security key-manager external remove-servers
uuid |
string |
path |
True |
server |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536828 |
External key management is not enabled for the SVM. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536843 |
Key management server is not configured for the SVM. |
65536700 |
The key server contains keys that are currently in use and not available from any other configured key server in the SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
