Delete a FlexCache volume
DELETE /storage/flexcache/flexcaches/{uuid}
Deletes a FlexCache. If a FlexCache volume is online, it is offlined before deletion.
Related ONTAP commands
volume flexcache delete
Learn more
uuid |
string |
path |
True |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846879 |
The specified volume UUID is not a FlexCache volume |
66846731 |
Failed to delete the FlexCache volume |
524546 |
Failed to delete the FlexCache volume because the FlexCache volume is not unmounted |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
