Delete an NVMe namespace
DELETE /storage/namespaces/{uuid}
Deletes an NVMe namespace.
Related ONTAP commands
vserver nvme namespace delete
Learn more
uuid |
string |
path |
True |
The unique identifier of the NVMe namespace to delete. |
allow_delete_while_mapped |
boolean |
query |
False |
Allows deletion of a mapped NVMe namespace. A mapped NVMe namespace might be in use. Deleting a mapped namespace also deletes the namespace map and makes the data no longer available, possibly causing a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090016 |
The namespace's aggregate is offline. The aggregate must be online to modify or remove the namespace. |
72090017 |
The namespace's volume is offline. The volume must be online to modify or remove the namespace. |
72090006 |
The specified namespace was not found. |
72090007 |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
