REST API reference
Deletes a snapshot copy policy
learn more
  • [doc /storage/snapshot-policies](#docs-storage-storage_snapshot-policies)
DELETE /storage/snapshot-policies/{uuid}
Deletes a Snapshot copy policy
  • snapshot policy delete
uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638415
Cannot delete policy. Reason: Policy is in use by at least one volume.
1638416
Cannot delete policy. Reason: Cannot verify whether policy is in use.
1638430
Cannot delete policy. Reason: Policy is in use by at least one Vserver.
1638430
Cannot delete built-in policy.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
