Deletes a volume if the uuid belongs to a volume, all of its blocks are freed and returned to its containing aggregate if a volume is online, it is offlined before deletion
volume clone delete
learn more
doc /storage/volumes](#docs-storage-storage_volumes)
DELETE /storage/volumes/{uuid}
Deletes a volume. If the UUID belongs to a volume, all of its blocks are freed and returned to its containing aggregate. If a volume is online, it is offlined before deletion.
Related ONTAP commands
volume delete -
volume clone delete
Learn more
uuid |
string |
path |
True |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
