REST API reference
Deletes an event filter
learn more
  • [doc /support/ems/filters/{name}](#docs-support-support_ems_filters_{name})
DELETE /support/ems/filters/{name}
Deletes an event filter.
  • event filter delete
name
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983113
Default filters cannot be modified or removed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
