Deletes the svm peer relationship
example
deletes an svm peer relationship <br/>
delete "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
<br/>
# learn more
* [doc /svm/peers](#docs-svm-svm_peers)
DELETE /svm/peers/{peer.uuid}
Deletes the SVM peer relationship.
Related ONTAP commands
vserver peer delete
Example
Deletes an SVM peer relationship.
DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Learn more
peer.uuid |
string |
path |
True |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
