REST API reference
Retrieves an application
  • <template> the property corresponding to the templatename of the application # property overview an application includes three main groups or properties
  • generic properties - such as the name, templatename, and state of the application these properties are all inexpensive to retrieve and their meaning is consistent for every type of application
  • statistics* - application statistics report live usage data about the application and its components various space and iops details are included at both the application level and at a per component level the application model includes a detailed description of each property these properties are slightly more expensive than the generic properties because live data must be collected from every storage element in the application
  • <template> - the property corresponding to the value of the templatename returns the contents of the application in the same layout that was used to provision the application this information is very expensive to retrieve because it requires collecting information about all the storage and access settings for every element of the application there are a few notable limitations to what can be returned in the <template> section:
  • the new_igroups array of many san templates is not returned by get this property allows igroup creation in the same call that creates an application, but is not a property of the application itself the new_igroups array is allowed during patch operations, but that does not modify the new_igroups of the application it is another way to allow igroup creation while updating the application to use a different igroup
  • the vdi_on_san and vdi_on_nas desktopscount property is rounded to the nearest 1000 during creation, and is reported with that rounding applied
  • the mongo_db_on_san datasetelement_count property is rounded up to an even number, and is reported with that rounding applied
  • the sql_on_san and sql_on_smb server_cores_count property is limited to 8 for get operations higher values are accepted by post, but the impact of the server_cores_count property on the application layout currently reaches its limit at 8 # learn more
  • [doc /application](#docs-application-overview)
GET /application/applications/{uuid}
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
  • <template> the property corresponding to the template.name of the application
Property overview
An application includes three main groups or properties.
  • Generic properties - such as the name, template.name, and state of the application. These properties are all inexpensive to retrieve and their meaning is consistent for every type of application.
  • statistics.* - application statistics report live usage data about the application and its components. Various space and IOPS details are included at both the application level and at a per component level. The application model includes a detailed description of each property. These properties are slightly more expensive than the generic properties because live data must be collected from every storage element in the application.
  • <template> - the property corresponding to the value of the template.name returns the contents of the application in the same layout that was used to provision the application. This information is very expensive to retrieve because it requires collecting information about all the storage and access settings for every element of the application. There are a few notable limitations to what can be returned in the <template> section:
    • The new_igroups array of many SAN templates is not returned by GET. This property allows igroup creation in the same call that creates an application, but is not a property of the application itself. The new_igroups array is allowed during PATCH operations, but that does not modify the new_igroups of the application. It is another way to allow igroup creation while updating the application to use a different igroup.
    • The vdi_on_san and vdi_on_nas desktops.count property is rounded to the nearest 1000 during creation, and is reported with that rounding applied.
    • The mongo_db_on_san dataset.element_count property is rounded up to an even number, and is reported with that rounding applied.
    • The sql_on_san and sql_on_smb server_cores_count property is limited to 8 for GET operations. Higher values are accepted by POST, but the impact of the server_cores_count property on the application layout currently reaches its limit at 8.
Learn more
uuid
string
path
True
Application UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
creation_timestamp
string
The time when the application was created
generation
integer
The generation number of the application. This indicates which features are supported on the application. For example, generation 1 applications do not support snapshots. Support for snapshots was added at generation 2. Any future generation numbers and their feature set will be documented
maxdata_on_san
maxdata_on_san
MAX Data application using SAN.
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
name
string
Application Name. This field is user supplied when the application is created. Required in the POST body
nas
nas
A generic NAS application.
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
Oracle RAC using NFS.
oracle_rac_on_san
oracle_rac_on_san
Oracle RAC using SAN.
protection_granularity
string
Protection granularity determines the scope of Snapshot operations for the application. Possible values are "application" and "component". If the value is "application", Snapshot operations are performed on the entire application. If the value is "component", Snapshot operations are performed separately on the application components
rpo
rpo
san
san
A generic SAN application.
sql_on_san
sql_on_san
Microsoft SQL using SAN.
sql_on_smb
sql_on_smb
Microsoft SQL using SMB.
state
string
The state of the application. For full functionality, applications must be in the online state. Other states indicate that the application is in a transient state and not all operations are supported
statistics
statistics
svm
svm
template
template
uuid
string
Application UUID. This field is generated when the application is created. Required in the URL
vdi_on_nas
vdi_on_nas
A VDI application using NAS.
vdi_on_san
vdi_on_san
A VDI application using SAN.
vsi_on_nas
vsi_on_nas
A VSI application using NAS.
vsi_on_san
vsi_on_san
A VSI application using SAN.
      "href": "/api/resourcelink"
    "snapshots": {
  "creation_timestamp": "string",
  "generation": 0,
  "maxdata_on_san": {
    "app_type": "string",
    "application_components": [
        "file_system": "string",
        "host_management_url": "string",
        "host_name": "string",
        "igroup_name": "string",
        "metadata": [
            "key": "string",
            "value": "string"
        "name": "string",
        "protection_type": {
          "local_rpo": "string",
          "remote_rpo": "string"
        "storage_service": {
          "name": "string"
    "metadata": [
        "key": "string",
        "value": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
        "os_type": "string",
        "protocol": "string"
    "ocsm_url": "string",
    "os_type": "string"
  "mongo_db_on_san": {
    "dataset": {
        "name": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
    "primary_igroup_name": "string",
    "secondary_igroups": [
        "name": "string"
  "name": "string",
  "nas": {
        "name": "string",
          "name": "string"
    "cifs_access": [
        "access": "string",
        "user_or_group": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
  "oracle_on_nfs": {
    "archive_log": {
        "name": "string"
    "db": {
        "name": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
    "ora_home": {
        "name": "string"
    "redo_log": {
        "name": "string"
  "oracle_on_san": {
    "archive_log": {
        "name": "string"
    "db": {
        "name": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
    "ora_home": {
        "name": "string"
    "redo_log": {
        "name": "string"
  "oracle_rac_on_nfs": {
    "archive_log": {
        "name": "string"
    "db": {
        "name": "string"
    "grid_binary": {
        "name": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
    "ora_home": {
        "name": "string"
    "oracle_crs": {
        "name": "string"
    "redo_log": {
        "name": "string"
  "oracle_rac_on_san": {
    "archive_log": {
        "name": "string"
    "db": {
        "name": "string"
    "db_sids": [
    "grid_binary": {
        "name": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
    "ora_home": {
        "name": "string"
    "oracle_crs": {
        "name": "string"
    "redo_log": {
        "name": "string"
  "protection_granularity": "string",
  "rpo": {
    "components": [
        "name": "string",
        "rpo": {
          "local": {
            "description": "string",
            "name": "string"
          "remote": {
            "name": "string"
        "uuid": "string"
    "local": {
      "name": "string"
    "remote": {
      "name": "string"
  "san": {
        "name": "string",
          "name": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
  "sql_on_san": {
    "db": {
        "name": "string"
    "log": {
        "name": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
    "temp_db": {
        "name": "string"
  "sql_on_smb": {
    "access": {
      "installer": "string",
      "service_account": "string"
    "db": {
        "name": "string"
    "log": {
        "name": "string"
    "temp_db": {
        "name": "string"
  "state": "string",
  "statistics": {
    "components": [
        "iops": {
          "per_tb": 0,
          "total": 0
        "latency": {
          "average": 0,
          "raw": 0
        "name": "string",
        "snapshot": {
          "reserve": 0,
          "used": 0
        "space": {
          "available": 0,
          "logical_used": 0,
          "provisioned": 0,
          "reserved_unused": 0,
          "savings": 0,
          "used": 0,
          "used_excluding_reserves": 0,
          "used_percent": 0
          "name": "string",
          "uuid": "string"
        "uuid": "string"
    "iops": {
      "per_tb": 0,
      "total": 0
    "latency": {
      "average": 0,
      "raw": 0
    "snapshot": {
      "reserve": 0,
      "used": 0
    "space": {
      "available": 0,
      "logical_used": 0,
      "provisioned": 0,
      "savings": 0,
      "used": 0,
      "used_percent": 0
  "svm": {
    "name": "string",
    "uuid": "string"
  "template": {
    "name": "string",
    "protocol": "string",
    "version": 0
  "uuid": "string",
  "vdi_on_nas": {
    "desktops": {
        "name": "string"
    "hyper_v_access": {
    "nfs_access": [
        "access": "string",
        "host": "string"
  "vdi_on_san": {
    "desktops": {
        "name": "string"
    "hypervisor": "string",
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
  "vsi_on_nas": {
    "datastore": {
        "name": "string"
    "hyper_v_access": {
    "nfs_access": [
        "access": "string",
        "host": "string"
  "vsi_on_san": {
    "datastore": {
        "name": "string"
    "new_igroups": [
        "initiators": [
          "string"
        "name": "string",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
snapshots
metadata
key
string
Key to look up metadata associated with an application component. Optional in the POST body
value
string
Value associated with the key. Optional in the POST body
protection_type
local_rpo
string
The local rpo of the application component. Optional in the POST or PATCH body
remote_rpo
string
The remote rpo of the application component. Optional in the POST or PATCH body
storage_service
name
string
The storage service of the application component. Optional in the POST or PATCH body
maxdata_on_san_application_components
application-components
file_system
string
Defines the kind of file system that will be installed on this application component. Optional in the POST body
host_management_url
string
The host management URL for this application component
host_name
string
FQDN of the L2 host that contains the hot tier of this application component. Required in the POST body
igroup_name
string
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup. Required in the POST body and optional in the PATCH body
lun_count
integer
The number of LUNs in the application component. Required in the POST body
metadata
array[metadata]
name
string
The name of the application component. Required in the POST body and optional in the PATCH body
protection_type
protection_type
storage_service
storage_service
total_size
integer
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body
metadata
key
string
Key to look up metadata associated with an application. Optional in the POST body
value
string
maxdata_on_san_new_igroups
The list of initiator groups to create.
initiators
array[string]
name
string
The name of the new initiator group. Required in the POST body and optional in the PATCH body
os_type
string
The name of the host OS accessing the application. The default value is the host OS that is running the application. Optional in the POST or PATCH body
protocol
string
The protocol of the new initiator group. Optional in the POST or PATCH body
maxdata_on_san
app_type
string
Type of the application that is being deployed on the L2. Required in the POST body
array[maxdata_on_san_application_components]
application-components. Optional in the POST or PATCH body
metadata
array[metadata]
new_igroups
array[maxdata_on_san_new_igroups]
The list of initiator groups to create. Optional in the POST or PATCH body
ocsm_url
string
The OnCommand System Manager URL for this application
os_type
string
The name of the host OS running the application. Required in the POST body
storage_service
name
string
The storage service of the database. Optional in the POST or PATCH body
dataset
element_count
integer
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range. Optional in the POST body
replication_factor
integer
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary. Optional in the POST body
size
integer
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body and optional in the PATCH body
storage_service
storage_service
mongo_db_on_san_new_igroups
initiators
array[string]
name
string
os_type
string
protocol
string
protection_type
local_rpo
string
The local rpo of the application. Optional in the POST or PATCH body
remote_rpo
string
The remote rpo of the application. Optional in the POST body
secondary_igroups
name
string
The name of the initiator group for each secondary. Optional in the POST or PATCH body
mongo_db_on_san
MongoDB using SAN.
dataset
dataset
new_igroups
array[mongo_db_on_san_new_igroups]
os_type
string
The name of the host OS running the application. Optional in the POST body
primary_igroup_name
string
The initiator group for the primary. Required in the POST body and optional in the PATCH body
protection_type
protection_type
secondary_igroups
array[secondary_igroups]
name
string
The name of the application component. Optional in the POST or PATCH body
share_count
integer
The number of shares in the application component. Optional in the POST body
storage_service
storage_service
total_size
integer
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST or PATCH body
app_cifs_access
The list of CIFS access controls.
access
string
The CIFS access granted to the user or group. Optional in the POST body
user_or_group
string
The name of the CIFS user or group that will be granted access. Optional in the POST body
app_nfs_access
The list of NFS access controls.
access
string
The NFS access granted. Optional in the POST body
host
string
The name of the NFS entity granted access. Optional in the POST body
nas
array[application_components]
cifs_access
array[app_cifs_access]
The list of CIFS access controls. Optional in the POST body
nfs_access
array[app_nfs_access]
The list of NFS access controls. Optional in the POST body
protection_type
protection_type
storage_service
name
string
The storage service of the archive log. Optional in the POST or PATCH body
archive_log
size
integer
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST or PATCH body
storage_service
storage_service
db
size
integer
storage_service
storage_service
storage_service
name
string
The storage service of the ORACLE_HOME storage volume. Optional in the POST or PATCH body
ora_home
size
integer
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST or PATCH body
storage_service
storage_service
storage_service
name
string
The storage service of the redo log group. Optional in the POST or PATCH body
redo_log
mirrored
boolean
Should the redo log group be mirrored? Optional in the POST body
size
integer
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body and optional in the PATCH body
storage_service
storage_service
oracle_on_nfs
Oracle using NFS.
archive_log
archive_log
db
db
nfs_access
ora_home
ora_home
protection_type
protection_type
redo_log
redo_log
oracle_on_san_new_igroups
initiators
array[string]
name
string
os_type
string
protocol
string
oracle_on_san
Oracle using SAN.
archive_log
archive_log
db
db
igroup_name
string
new_igroups
array[oracle_on_san_new_igroups]
ora_home
ora_home
os_type
string
protection_type
protection_type
redo_log
redo_log
storage_service
name
string
The storage service of the Oracle grid binary storage volume. Optional in the POST or PATCH body
grid_binary
size
integer
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST or PATCH body
storage_service
storage_service
storage_service
name
string
The storage service of the Oracle CRS volume. Optional in the POST or PATCH body
oracle_crs
copies
integer
The number of CRS volumes. Optional in the POST body
size
integer
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST body
storage_service
storage_service
oracle_rac_on_nfs
archive_log
archive_log
db
db
grid_binary
grid_binary
nfs_access
ora_home
ora_home
oracle_crs
oracle_crs
protection_type
protection_type
redo_log
redo_log
db_sids
igroup_name
string
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup. Optional in the POST or PATCH body
oracle_rac_on_san_new_igroups
initiators
array[string]
name
string
os_type
string
protocol
string
oracle_rac_on_san
archive_log
archive_log
db
db
db_sids
array[db_sids]
grid_binary
grid_binary
new_igroups
array[oracle_rac_on_san_new_igroups]
ora_home
ora_home
oracle_crs
oracle_crs
os_type
string
protection_type
protection_type
redo_log
redo_log
local
description
string
A detailed description of the local RPO. This will include details about the snapshot schedule
name
string
The local RPO of the component. This indicates how often component snapshots are automatically created
remote
description
string
A detailed description of the remote RPO
name
string
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster
rpo
local
local
remote
remote
components
name
string
Component Name
rpo
rpo
uuid
string
Component UUID
local
description
string
name
string
The local RPO of the application. This indicates how often application snapshots are automatically created
remote
description
string
name
string
The remote RPO of the application. A remote RPO of zero indicates that the application is synchronously replicated to another cluster
rpo
components
array[components]
is_supported
boolean
Is RPO supported for this application? Generation 1 applications did not support snapshots or MetroCluster
local
local
remote
remote
igroup_name
string
lun_count
integer
The number of LUNs in the application component. Optional in the POST body
name
string
storage_service
storage_service
total_size
integer
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST or PATCH body
san_new_igroups
initiators
array[string]
name
string
os_type
string
protocol
string
san
new_igroups
array[san_new_igroups]
os_type
string
protection_type
protection_type
storage_service
name
string
The storage service of the db. Optional in the POST or PATCH body
db
size
integer
The size of the db. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body and optional in the PATCH body
storage_service
storage_service
storage_service
name
string
The storage service of the log db. Optional in the POST or PATCH body
log
size
integer
The size of the log db. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body and optional in the PATCH body
storage_service
storage_service
sql_on_san_new_igroups
initiators
array[string]
name
string
os_type
string
protocol
string
storage_service
name
string
The storage service of the temp db. Optional in the POST or PATCH body
temp_db
size
integer
The size of the temp db. Usage: {<integer>[KB|MB|GB|TB|PB]} Optional in the POST or PATCH body
storage_service
storage_service
sql_on_san
db
db
igroup_name
string
log
log
new_igroups
array[sql_on_san_new_igroups]
os_type
string
protection_type
protection_type
server_cores_count
integer
The number of server cores for the db. Optional in the POST body
temp_db
temp_db
access
installer
string
SQL installer admin user name. Optional in the POST body
service_account
string
SQL service account user name. Required in the POST body
sql_on_smb
access
access
db
db
log
log
protection_type
protection_type
server_cores_count
integer
temp_db
temp_db
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application component
total
integer
The total number of IOPS being used by the application component
latency
average
integer
The cumulative average response time in microseconds for this component
raw
integer
The cumulative response time in microseconds for this component
snapshot
reserve
integer
The amount of space reserved by the system for snapshots
used
integer
The amount of spacing currently in use by the system to store snapshots
space
available
integer
The available amount of space left in the application component. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available
  • readOnly: 1
logical_used
integer
The amount of space that would currently be used if no space saving features were enabled. For example, if compression were the only space saving feature enabled, this field would represent the uncompressed amount of space used
provisioned
integer
The originally requested amount of space that was provisioned for the application component
reserved_unused
integer
The amount of space reserved for system features such as snapshots that has not yet been used
savings
integer
The amount of space saved by all enabled space saving features
used
integer
The amount of space that is currently being used by the application component. Note that this includes any space reserved by the system for features such as snapshots
integer
The amount of space that is currently being used, excluding any space that is reserved by the system for features such as snapshots
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application component
storage_service
name
string
The storage service name. AFF systems support the extreme storage service. All other systems only support value
uuid
string
The storage service UUID
components
iops
iops
latency
latency
name
string
Component Name
shared_storage_pool
boolean
An application component is considered to use a shared storage pool if storage elements for for other components reside on the same aggregate as storage elements for this component
snapshot
snapshot
space
space
statistics_incomplete
boolean
If not all storage elements of the application component are currently available, the returned statistics might only include data from those elements that were available
storage_service
storage_service
uuid
string
Component UUID
iops
per_tb
integer
total
integer
latency
average
integer
The cumulative average response time in microseconds for this application
raw
integer
The cumulative response time in microseconds for this application
space
available
integer
The available amount of space left in the application. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available
  • readOnly: 1
logical_used
integer
provisioned
integer
reserved_unused
integer
savings
integer
used
integer
The amount of space that is currently being used by the application. Note that this includes any space reserved by the system for features such as snapshots
integer
used_percent
integer
statistics
components
array[components]
iops
iops
latency
latency
shared_storage_pool
boolean
An application is considered to use a shared storage pool if storage elements for multiple components reside on the same aggregate
snapshot
snapshot
space
space
boolean
If not all storage elements of the application are currently available, the returned statistics might only include data from those elements that were available
svm
name
string
SVM Name. Either the SVM name or UUID must be provided to create an application. Optional in the POST body
uuid
string
SVM UUID. Either the SVM name or UUID must be provided to create an application. Optional in the POST body
self
template
_links
self_link
name
string
The name of the template that was used to provision this application. Optional in the POST body
protocol
string
The protocol access of the template that was used to provision this application
version
integer
The version of the template that was used to provision this application. The template version changes only if the layout of the application changes over time. For example, redo logs in Oracle RAC templates were updated and provisioned differently in DATA ONTAP 9.3.0 compared to prior releases, so the version number was increased. If layouts change in the future, the changes will be documented along with the corresponding version numbers
  • readOnly: 1
storage_service
name
string
The storage service of the desktops. Optional in the POST or PATCH body
desktops
count
integer
The number of desktops to support. Optional in the POST or PATCH body
size
integer
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body
storage_service
storage_service
hyper_v_access
service_account
string
Hyper-V service account. Optional in the POST body
vdi_on_nas
desktops
desktops
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vdi_on_san_new_igroups
initiators
array[string]
name
string
protocol
string
vdi_on_san
desktops
desktops
hypervisor
string
The name of the hypervisor hosting the application. Required in the POST body
igroup_name
string
new_igroups
array[vdi_on_san_new_igroups]
protection_type
protection_type
storage_service
name
string
The storage service of the datastore. Optional in the POST or PATCH body
datastore
count
integer
The number of datastores to support. Optional in the POST or PATCH body
size
integer
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]} Required in the POST body
storage_service
storage_service
vsi_on_nas
datastore
datastore
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vsi_on_san_new_igroups
initiators
array[string]
name
string
protocol
string
vsi_on_san
datastore
datastore
hypervisor
string
igroup_name
string
new_igroups
array[vsi_on_san_new_igroups]
protection_type
protection_type
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
