REST API reference
Retrieves a specific license package
  • system license show-status
learn more
  • [doc /cluster/licensing/licenses/{name}](#docs-cluster-cluster_licensing_licenses_{name})
GET /cluster/licensing/licenses/{name}
Retrieves a specific license package.
name
string
path
True
Name of the license package.
name
string
query
False
Filter by name
scope
string
query
False
Filter by scope
state
string
query
False
Filter by state
licenses.start_time
string
query
False
Filter by licenses.start_time
licenses.evaluation
boolean
query
False
Filter by licenses.evaluation
licenses.owner
string
query
False
Filter by licenses.owner
licenses.serial_number
string
query
False
Filter by licenses.serial_number
licenses.active
boolean
query
False
Filter by licenses.active
licenses.expiry_time
string
query
False
Filter by licenses.expiry_time
licenses.capacity.used_size
integer
query
False
Filter by licenses.capacity.used_size
licenses.capacity.maximum_size
integer
query
False
Filter by licenses.capacity.maximum_size
licenses.compliance.state
string
query
False
Filter by licenses.compliance.state
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
licenses
array[licenses]
Installed licenses of the package.
name
string
Name of the license.
scope
string
Scope of the license.
state
string
Summary state of package based on all installed licenses.
      "href": "/api/resourcelink"
  "licenses": [
      "capacity": {
        "maximum_size": 0,
        "used_size": 0
      "compliance": {
        "state": "compliant"
      "expiry_time": "2019-03-02 19:00:00 UTC",
      "owner": "cluster1",
      "serial_number": "123456789",
      "start_time": "2019-02-02 19:00:00 UTC"
  "name": "NFS",
  "scope": "string",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
capacity
maximum_size
integer
Licensed capacity size (in bytes) that can be used.
used_size
integer
Capacity that is currently used (in bytes).
compliance
state
string
Compliance state of the license.
licenses
active
boolean
A flag indicating whether the license is currently being enforced.
capacity
capacity
compliance
compliance
evaluation
boolean
A flag indicating whether the license is in evaluation mode.
expiry_time
string
Date and time when the license expires.
owner
string
Cluster, node or license manager that owns the license.
serial_number
string
Serial number of the license.
start_time
string
Date and time when the license starts.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
