Retrieve nodes in a cluster
GET /cluster/nodes
Retrieves the nodes in the cluster.
Learn more
ha.auto_giveback |
boolean |
query |
False |
Filter by ha.auto_giveback |
ha.enabled |
boolean |
query |
False |
Filter by ha.enabled |
ha.partners.name |
string |
query |
False |
Filter by ha.partners.name |
ha.partners.uuid |
string |
query |
False |
Filter by ha.partners.uuid |
uptime |
integer |
query |
False |
Filter by uptime |
date |
string |
query |
False |
Filter by date |
membership |
string |
query |
False |
Filter by membership |
serial_number |
string |
query |
False |
Filter by serial_number |
controller.over_temperature |
string |
query |
False |
Filter by controller.over_temperature |
controller.flash_cache.serial_number |
string |
query |
False |
Filter by controller.flash_cache.serial_number |
controller.flash_cache.hardware_revision |
string |
query |
False |
Filter by controller.flash_cache.hardware_revision |
controller.flash_cache.capacity |
integer |
query |
False |
Filter by controller.flash_cache.capacity |
controller.flash_cache.model |
string |
query |
False |
Filter by controller.flash_cache.model |
controller.flash_cache.slot |
string |
query |
False |
Filter by controller.flash_cache.slot |
controller.flash_cache.state |
string |
query |
False |
Filter by controller.flash_cache.state |
controller.flash_cache.firmware_version |
string |
query |
False |
Filter by controller.flash_cache.firmware_version |
controller.flash_cache.part_number |
string |
query |
False |
Filter by controller.flash_cache.part_number |
controller.frus.id |
integer |
query |
False |
Filter by controller.frus.id |
controller.frus.type |
string |
query |
False |
Filter by controller.frus.type |
controller.frus.state |
string |
query |
False |
Filter by controller.frus.state |
location |
string |
query |
False |
Filter by location |
model |
string |
query |
False |
Filter by model |
management_interfaces.ip.address |
string |
query |
False |
Filter by management_interfaces.ip.address |
management_interfaces.uuid |
string |
query |
False |
Filter by management_interfaces.uuid |
management_interfaces.name |
string |
query |
False |
Filter by management_interfaces.name |
service_processor.link_status |
string |
query |
False |
Filter by service_processor.link_status |
service_processor.state |
string |
query |
False |
Filter by service_processor.state |
service_processor.firmware_version |
string |
query |
False |
Filter by service_processor.firmware_version |
service_processor.dhcp_enabled |
boolean |
query |
False |
Filter by service_processor.dhcp_enabled |
service_processor.ipv4_interface.address |
string |
query |
False |
Filter by service_processor.ipv4_interface.address |
service_processor.ipv4_interface.netmask |
string |
query |
False |
Filter by service_processor.ipv4_interface.netmask |
service_processor.ipv4_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv4_interface.gateway |
service_processor.mac_address |
string |
query |
False |
Filter by service_processor.mac_address |
service_processor.ipv6_interface.address |
string |
query |
False |
Filter by service_processor.ipv6_interface.address |
service_processor.ipv6_interface.netmask |
string |
query |
False |
Filter by service_processor.ipv6_interface.netmask |
service_processor.ipv6_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv6_interface.gateway |
name |
string |
query |
False |
Filter by name |
version.minor |
integer |
query |
False |
Filter by version.minor |
version.full |
string |
query |
False |
Filter by version.full |
version.major |
integer |
query |
False |
Filter by version.major |
version.generation |
integer |
query |
False |
Filter by version.generation |
cluster_interfaces.ip.address |
string |
query |
False |
Filter by cluster_interfaces.ip.address |
cluster_interfaces.uuid |
string |
query |
False |
Filter by cluster_interfaces.uuid |
cluster_interfaces.name |
string |
query |
False |
Filter by cluster_interfaces.name |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"cluster_interfaces": [
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"controller": {
"flash_cache": [
"capacity": 1024000000000,
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": 0,
"state": "string",
"type": "string"
"over_temperature": "string"
"date": "2017-01-25 11:20:13 +0400",
"ha": {
"partners": [
"name": "node1",
"location": "rack 2 row 5",
"management_interfaces": [
"ip": {
"name": "lif1",
"membership": "string",
"model": "FAS3070",
"name": "node-01",
"serial_number": "4048820-60-9",
"service_processor": {
"firmware_version": "string",
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"ipv6_interface": {
"netmask": "24"
"link_status": "string",
"mac_address": "string",
"state": "string"
"uptime": 300536,
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": 9,
"major": 4,
"minor": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node_setup_ip
The IP configuration for cluster setup.
address |
string |
IPv4 or IPv6 address |
cluster_interface
The cluster network IP address of the node to be added.
ip
IP information
address |
string |
cluster_interfaces
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
flash_cache
capacity |
integer |
Size in bytes |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
integer |
state |
string |
type |
string |
controller
Controller information
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
A list of frus in the node. Only returned when requested by name. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
partners
_links |
name |
string |
uuid |
string |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
partners |
array[partners] |
The nodes in this node's High Availability (HA) group. |
The management interface of the node to be added. The netmask is set based on the management interface of the cluster or the managment interfaces of other nodes.
Network interface
_links |
ip |
IP information |
name |
string |
uuid |
string |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipv6_interface
address |
string |
gateway |
string |
netmask |
string |
service_processor
dhcp_enabled |
boolean |
Set to true to use DHCP to configure an IPv4 interface. |
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
Object to setup an interface along with its default router. |
ipv6_interface |
link_status |
string |
mac_address |
string |
state |
string |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
records
Complete node information
_links |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
Specifies the ISO-8601 format date and time on the node. |
ha |
location |
string |
management_interfaces |
array[management_interfaces] |
membership |
string |
Possible values:
model |
string |
name |
string |
serial_number |
string |
service_processor |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
