Retrieves the details of a physical port, vlan, or lag
network port ifgrp show -
network port vlan show
learn more
doc /network/ethernet/ports](#docs-networking-network_ethernet_ports)
GET /network/ethernet/ports/{uuid}
Retrieves the details of a physical port, VLAN, or LAG.
Related ONTAP commands
network port show -
Learn more
uuid |
string |
path |
True |
Port UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
broadcast_domain |
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input. |
enabled |
boolean |
lag |
mac_address |
string |
mtu |
integer |
MTU of the port in bytes. Set by broadcast domain. |
name |
string |
Portname, such as e0a, e1b-100 (VLAN on ethernet), a0c (LAG/ifgrp), a0d-200 (vlan on LAG/ifgrp) |
node |
speed |
integer |
Link speed in Mbps |
state |
string |
Operational state of the port. |
type |
string |
Type of physical or virtual port |
uuid |
string |
Port UUID |
vlan |
"href": "/api/resourcelink"
"broadcast_domain": {
"ipspace": {
"name": "ipspace1"
"name": "bd1",
"lag": {
"active_ports": [
"name": "e1b",
"node": {
"name": "node1"
"distribution_policy": "string",
"member_ports": [
"name": "e1b",
"node": {
"name": "node1"
"mode": "string"
"mac_address": "01:02:03:04:05:06",
"mtu": 1500,
"name": "e1b",
"node": {
"name": "node1",
"speed": 1000,
"state": "string",
"type": "string",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vlan": {
"base_port": {
"name": "e1b",
"node": {
"name": "node1"
"tag": 100
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
name |
string |
Name of the broadcast domain's IPspace |
broadcast_domain
_links |
ipspace |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
node
name |
string |
Name of node on which the port is located. |
active_ports
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
member_ports
_links |
name |
string |
node |
uuid |
string |
lag
active_ports |
array[active_ports] |
Active ports of a LAG (ifgrp). (Some member ports may be inactive.) |
distribution_policy |
string |
Policy for mapping flows to ports for outbound packets through a LAG (ifgrp). |
member_ports |
array[member_ports] |
mode |
string |
Determines how the ports interact with the switch. |
node
_links |
name |
string |
uuid |
string |
base_port
_links |
name |
string |
node |
uuid |
string |
vlan
base_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
tag |
integer |
VLAN ID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
