REST API reference
Retrieves an fc login
learn more
  • san: [doc /network/fc/logins](#docs-san-network_fc_logins)
  • nvme: [doc /network/fc/logins](#docs-nvme-network_fc_logins)
GET /network/fc/logins/{interface.uuid}/{initiator.wwpn}
Retrieves an FC login.
  • vserver fcp initiator show
interface.uuid
string
path
True
The unique identifier of the FC interface through which the initiator logged in.
initiator.wwpn
string
path
True
The world wide port name (WWPN) of the initiator.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
igroups
array[igroups]
The initiator groups in which the initiator is a member.
initiator
initiator
Information about the logged in FC initiator.
interface
interface
An FC interface.
protocol
string
The data protocol used to perform the login.
svm
svm
    "next": {
      "href": "/api/resourcelink"
  "igroups": [
      "name": "igroup1",
  "initiator": {
    "aliases": [
      "alias1"
    "port_address": "5060A",
    "wwnn": "2f:a0:00:a0:98:0b:56:13",
    "wwpn": "2f:a0:00:a0:98:0b:56:13"
  "interface": {
    "name": "lif1",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
    "wwpn": "20:00:00:50:56:b4:13:a8"
  "protocol": "string",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The Fibre Channel login specified does not exist.
5374881
The Fibre Channel interface specified does not exist.
5373983
An invalid WWPN was supplied.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
igroups
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiator
aliases
array[string]
The logged in initiator world wide port name (WWPN) aliases.
port_address
string
The port address of the initiator's FC port.
Each port in an FC switched fabric has its own unique port address for routing purposes. The port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the initiator port.
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a hexadecimal encoded numeric value.
wwnn
string
The logged in initiator world wide node name (WWNN).
wwpn
string
The logged in initiator WWPN.
interface
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
