REST API reference
Retrieves fc logins
learn more
  • san: [doc /network/fc/logins](#docs-san-network_fc_logins)
  • nvme: [doc /network/fc/logins](#docs-nvme-network_fc_logins)
GET /network/fc/logins
Retrieves FC logins.
  • vserver fcp initiator show
igroups.uuid
string
query
False
Filter by igroups.uuid
igroups.name
string
query
False
Filter by igroups.name
protocol
string
query
False
Filter by protocol
interface.name
string
query
False
Filter by interface.name
interface.wwpn
string
query
False
Filter by interface.wwpn
interface.uuid
string
query
False
Filter by interface.uuid
initiator.port_address
string
query
False
Filter by initiator.port_address
initiator.aliases
string
query
False
Filter by initiator.aliases
initiator.wwpn
string
query
False
Filter by initiator.wwpn
initiator.wwnn
string
query
False
Filter by initiator.wwnn
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[fc_login]
    "next": {
      "href": "/api/resourcelink"
  "records": [
        "next": {
      "igroups": [
          "name": "igroup1",
      "initiator": {
        "aliases": [
          "alias1"
        "port_address": "5060A",
        "wwnn": "2f:a0:00:a0:98:0b:56:13",
        "wwpn": "2f:a0:00:a0:98:0b:56:13"
      "interface": {
        "name": "lif1",
        "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
        "wwpn": "20:00:00:50:56:b4:13:a8"
      "protocol": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
igroups
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiator
Information about the logged in FC initiator.
aliases
array[string]
The logged in initiator world wide port name (WWPN) aliases.
port_address
string
The port address of the initiator's FC port.
Each port in an FC switched fabric has its own unique port address for routing purposes. The port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the initiator port.
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a hexadecimal encoded numeric value.
wwnn
string
The logged in initiator world wide node name (WWNN).
wwpn
string
The logged in initiator WWPN.
interface
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
fc_login
A Fibre Channel (FC) login represents a connection formed by an FC initiator that has successfully logged in to ONTAP. This represents the FC login on which higher-level protocols such as Fibre Channel Protocol and NVMe over Fibre Channel (NVMe/FC) rely.
_links
_links
igroups
array[igroups]
The initiator groups in which the initiator is a member.
initiator
initiator
interface
interface
An FC interface.
protocol
string
The data protocol used to perform the login.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
