Retrieves a particular fpolicy engine configuration of a specifed svm a cluster-level fpolicy engine configuration cannot be retrieved for a data svm
learn more
doc /protocols/fpolicy/{svmuuid}/engines](#docs-nas-protocols_fpolicy_{svmuuid}_engines)
GET /protocols/fpolicy/{svm.uuid}/engines/{name}
Retrieves a particular FPolicy engine configuration of a specifed SVM. A cluster-level FPolicy engine configuration cannot be retrieved for a data SVM.
Related ONTAP commands
fpolicy policy external-engine show
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
name |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
name |
string |
Specifies the name to assign to the external server configuration. |
port |
integer |
Port number of the FPolicy server application. |
primary_servers |
array[string] |
secondary_servers |
array[string] |
type |
string |
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
"name": "fp_ex_eng",
"port": 9876,
"primary_servers": [
"10.132.145.20",
"10.140.101.109"
"secondary_servers": [
"10.132.145.20",
"10.132.145.21"
"type": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
