Retrieves fpolicy event configurations for all events for a specified svm ontap allows the creation of cluster-level fpolicy events that act as a template for all the data svms belonging to the cluster these cluster-level fpolicy events are also retrieved for the specified svm
learn more
doc /protocols/fpolicy/{svmuuid}/events](#docs-nas-protocols_fpolicy_{svmuuid}_events)
GET /protocols/fpolicy/{svm.uuid}/events
Retrieves FPolicy event configurations for all events for a specified SVM. ONTAP allows the creation of cluster-level FPolicy events that act as a template for all the data SVMs belonging to the cluster. These cluster-level FPolicy events are also retrieved for the specified SVM.
Related ONTAP commands
fpolicy policy event show
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
file_operations.setattr |
boolean |
query |
False |
Filter by file_operations.setattr |
file_operations.read |
boolean |
query |
False |
Filter by file_operations.read |
file_operations.rename_dir |
boolean |
query |
False |
Filter by file_operations.rename_dir |
file_operations.symlink |
boolean |
query |
False |
Filter by file_operations.symlink |
file_operations.create |
boolean |
query |
False |
Filter by file_operations.create |
file_operations.link |
boolean |
query |
False |
Filter by file_operations.link |
file_operations.delete_dir |
boolean |
query |
False |
Filter by file_operations.delete_dir |
file_operations.close |
boolean |
query |
False |
Filter by file_operations.close |
file_operations.lookup |
boolean |
query |
False |
Filter by file_operations.lookup |
file_operations.create_dir |
boolean |
query |
False |
Filter by file_operations.create_dir |
file_operations.delete |
boolean |
query |
False |
Filter by file_operations.delete |
file_operations.getattr |
boolean |
query |
False |
Filter by file_operations.getattr |
file_operations.open |
boolean |
query |
False |
Filter by file_operations.open |
file_operations.rename |
boolean |
query |
False |
Filter by file_operations.rename |
file_operations.write |
boolean |
query |
False |
Filter by file_operations.write |
protocol |
string |
query |
False |
Filter by protocol |
filters.setattr_with_group_change |
boolean |
query |
False |
Filter by filters.setattr_with_group_change |
filters.open_with_write_intent |
boolean |
query |
False |
Filter by filters.open_with_write_intent |
filters.setattr_with_sacl_change |
boolean |
query |
False |
Filter by filters.setattr_with_sacl_change |
filters.setattr_with_size_change |
boolean |
query |
False |
Filter by filters.setattr_with_size_change |
filters.offline_bit |
boolean |
query |
False |
Filter by filters.offline_bit |
filters.setattr_with_access_time_change |
boolean |
query |
False |
Filter by filters.setattr_with_access_time_change |
filters.setattr_with_creation_time_change |
boolean |
query |
False |
Filter by filters.setattr_with_creation_time_change |
filters.setattr_with_dacl_change |
boolean |
query |
False |
Filter by filters.setattr_with_dacl_change |
filters.setattr_with_mode_change |
boolean |
query |
False |
Filter by filters.setattr_with_mode_change |
filters.close_with_modification |
boolean |
query |
False |
Filter by filters.close_with_modification |
filters.close_with_read |
boolean |
query |
False |
Filter by filters.close_with_read |
filters.setattr_with_modify_time_change |
boolean |
query |
False |
Filter by filters.setattr_with_modify_time_change |
filters.first_read |
boolean |
query |
False |
Filter by filters.first_read |
filters.write_with_size_change |
boolean |
query |
False |
Filter by filters.write_with_size_change |
filters.open_with_delete_intent |
boolean |
query |
False |
Filter by filters.open_with_delete_intent |
filters.setattr_with_owner_change |
boolean |
query |
False |
Filter by filters.setattr_with_owner_change |
filters.setattr_with_allocation_size_change |
boolean |
query |
False |
Filter by filters.setattr_with_allocation_size_change |
filters.monitor_ads |
boolean |
query |
False |
Filter by filters.monitor_ads |
filters.first_write |
boolean |
query |
False |
Filter by filters.first_write |
filters.close_without_modification |
boolean |
query |
False |
Filter by filters.close_without_modification |
filters.exclude_directory |
boolean |
query |
False |
Filter by filters.exclude_directory |
name |
string |
query |
False |
Filter by name |
volume_monitoring |
boolean |
query |
False |
Filter by volume_monitoring |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[fpolicy_event] |
"next": {
"href": "/api/resourcelink"
"records": [
"name": "event_nfs_close",
"protocol": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
close |
boolean |
File close operations |
create |
boolean |
File create operations |
create_dir |
boolean |
Directory create operations |
delete |
boolean |
File delete operations |
delete_dir |
boolean |
Directory delete operations |
getattr |
boolean |
Get attribute operations |
link |
boolean |
Link operations |
lookup |
boolean |
Lookup operations |
open |
boolean |
File open operations |
read |
boolean |
File read operations |
rename |
boolean |
File rename operations |
rename_dir |
boolean |
Directory rename operations |
setattr |
boolean |
Set attribute operations |
symlink |
boolean |
Symbolic link operations |
write |
boolean |
File write operations |
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
boolean |
Filter the client request for close with modification. |
close_with_read |
boolean |
Filter the client request for close with read. |
boolean |
Filter the client request for close without modification. |
exclude_directory |
boolean |
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored. |
first_read |
boolean |
Filter the client requests for the first-read. |
first_write |
boolean |
Filter the client requests for the first-write. |
monitor_ads |
boolean |
Filter the client request for alternate data stream. |
offline_bit |
boolean |
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed. |
boolean |
Filter the client request for open with delete intent. |
boolean |
Filter the client request for open with write intent. |
boolean |
Filter the client setattr requests for changing the access time of a file or directory. |
boolean |
Filter the client setattr requests for changing the allocation size of a file. |
boolean |
Filter the client setattr requests for changing the creation time of a file or directory. |
boolean |
Filter the client setattr requests for changing dacl on a file or directory. |
boolean |
Filter the client setattr requests for changing group of a file or directory. |
boolean |
Filter the client setattr requests for changing the mode bits on a file or directory. |
boolean |
Filter the client setattr requests for changing the modification time of a file or directory. |
boolean |
Filter the client setattr requests for changing owner of a file or directory. |
boolean |
Filter the client setattr requests for changing sacl on a file or directory. |
boolean |
Filter the client setattr requests for changing the size of a file. |
boolean |
Filter the client request for write with size change. |
fpolicy_event
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations |
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol. |
filters |
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations. |
name |
string |
Specifies the name of the FPolicy event. |
protocol |
string |
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
volume_monitoring |
boolean |
Specifies whether volume operation monitoring is required. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
