REST API reference
Retrieves a particular fpolicy policy configuration for a specified svm cluster-level fpolicy policy configuration details cannot be retrieved for a data svm
  • fpolicy policy scope show
  • fpolicy show # learn more
  • [doc /protocols/fpolicy/{svmuuid}/policies](#docs-nas-protocols_fpolicy_{svmuuid}_policies)
GET /protocols/fpolicy/{svm.uuid}/policies/{name}
Retrieves a particular FPolicy policy configuration for a specified SVM. Cluster-level FPolicy policy configuration details cannot be retrieved for a data SVM.
  • fpolicy policy show
  • fpolicy show
svm.uuid
string
path
True
name
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
fpolicy_engine_reference
FPolicy external engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
priority
integer
Specifies the priority that is assigned to this policy.
scope
scope
  "engine": {
        "href": "/api/resourcelink"
    "name": "string"
  "events": [
    "event_nfs_close",
    "event_open"
  "name": "fp_policy_1",
  "scope": {
    "exclude_export_policies": [
      "string"
    "exclude_extension": [
      "string"
    "exclude_shares": [
      "string"
    "exclude_volumes": [
      "vol1",
      "vol_svm1",
    "include_export_policies": [
      "string"
    "include_extension": [
      "string"
    "include_shares": [
      "sh1",
      "share_cifs"
    "include_volumes": [
      "vol1",
      "vol_svm1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
name
string
The name of the FPolicy external engine.
FPolicy events
_links
_links
name
string
scope
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
