Retrieves a kerberos interface
learn more
doc /protocols/nfs/kerberos/interfaces](#docs-nas-protocols_nfs_kerberos_interfaces)
GET /protocols/nfs/kerberos/interfaces/{uuid}
Retrieves a Kerberos interface.
Related ONTAP commands
vserver nfs kerberos interface show
Learn more
uuid |
string |
path |
True |
Network interface UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
Specifies if Kerberos is enabled. |
encryption_types |
array[string] |
interface |
Network interface |
spn |
string |
Service principal name. Valid in PATCH. |
svm |
"href": "/api/resourcelink"
"encryption_types": [
"string"
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"spn": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
