Retrieve the NFS configuration for an SVM
GET /protocols/nfs/services/{svm.uuid}
Retrieves the NFS configuration of an SVM.
Related ONTAP commands
vserver nfs show -
vserver nfs status
Learn more
svm.uuid  |
string  |
path  |
True  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
enabled  |
boolean  |
Specifies if the NFS service is administratively enabled.  |
protocol  |
state  |
string  |
Specifies the state of the NFS service on the SVM. The following values are supported:
svm  |
SVM, applies only to SVM-scoped objects.  |
transport  |
vstorage_enabled  |
boolean  |
Specifies whether VMware vstorage feature is enabled.  |
      "href": "/api/resourcelink"
  "protocol": {
    "v4_id_domain": "string"
  "state": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
v40_features
acl_enabled  |
boolean  |
Specifies whether NFSv4.0 ACLs is enabled.  |
read_delegation_enabled  |
boolean  |
Specifies whether NFSv4.0 Read Delegation is enabled.  |
write_delegation_enabled  |
boolean  |
Specifies whether NFSv4.0 Write Delegation is enabled.  |
v41_features
acl_enabled  |
boolean  |
Specifies whether NFSv4.1 ACLs is enabled.  |
pnfs_enabled  |
boolean  |
Specifies whether NFSv4.1 Parallel NFS is enabled.  |
boolean  |
Specifies whether NFSv4.1 Read Delegation is enabled.  |
boolean  |
Specifies whether NFSv4.1 Write Delegation is enabled.  |
protocol
v3_enabled  |
boolean  |
Specifies whether NFSv3 protocol is enabled.  |
v40_enabled  |
boolean  |
Specifies whether NFSv4.0 protocol is enabled.  |
v40_features  |
v41_enabled  |
boolean  |
Specifies whether NFSv4.1 protocol is enabled.  |
v41_features  |
v4_id_domain  |
string  |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
transport
tcp_enabled  |
boolean  |
Specifies whether TCP transports are enabled on the server.  |
udp_enabled  |
boolean  |
Specifies whether UDP transports are enabled on the server.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
