Retrieve NFS configuration for SVMs
GET /protocols/nfs/services
Retrieves the NFS configuration of SVMs.
Related ONTAP commands
vserver nfs show -
vserver nfs status
Learn more
vstorage_enabled |
boolean |
query |
False |
Filter by vstorage_enabled |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
protocol.v41_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.write_delegation_enabled |
protocol.v41_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.acl_enabled |
protocol.v41_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.read_delegation_enabled |
protocol.v41_features.pnfs_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.pnfs_enabled |
protocol.v40_enabled |
boolean |
query |
False |
Filter by protocol.v40_enabled |
protocol.v41_enabled |
boolean |
query |
False |
Filter by protocol.v41_enabled |
protocol.v4_id_domain |
string |
query |
False |
Filter by protocol.v4_id_domain |
protocol.v40_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.acl_enabled |
protocol.v40_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.write_delegation_enabled |
protocol.v40_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.read_delegation_enabled |
protocol.v3_enabled |
boolean |
query |
False |
Filter by protocol.v3_enabled |
transport.udp_enabled |
boolean |
query |
False |
Filter by transport.udp_enabled |
transport.tcp_enabled |
boolean |
query |
False |
Filter by transport.tcp_enabled |
state |
string |
query |
False |
Filter by state |
enabled |
boolean |
query |
False |
Filter by enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NFS Server Records |
records |
array[nfs_service] |
"next": {
"href": "/api/resourcelink"
"records": [
"protocol": {
"v4_id_domain": "string"
"state": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
v40_features
acl_enabled |
boolean |
Specifies whether NFSv4.0 ACLs is enabled. |
boolean |
Specifies whether NFSv4.0 Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.0 Write Delegation is enabled. |
v41_features
acl_enabled |
boolean |
Specifies whether NFSv4.1 ACLs is enabled. |
pnfs_enabled |
boolean |
Specifies whether NFSv4.1 Parallel NFS is enabled. |
boolean |
Specifies whether NFSv4.1 Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.1 Write Delegation is enabled. |
protocol
v3_enabled |
boolean |
Specifies whether NFSv3 protocol is enabled. |
v40_enabled |
boolean |
Specifies whether NFSv4.0 protocol is enabled. |
v40_features |
v41_enabled |
boolean |
Specifies whether NFSv4.1 protocol is enabled. |
v41_features |
v4_id_domain |
string |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
transport
tcp_enabled |
boolean |
Specifies whether TCP transports are enabled on the server. |
udp_enabled |
boolean |
Specifies whether UDP transports are enabled on the server. |
nfs_service
_links |
enabled |
boolean |
Specifies if the NFS service is administratively enabled. |
protocol |
state |
string |
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests. |
svm |
transport |
vstorage_enabled |
boolean |
Specifies whether VMware vstorage feature is enabled. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
