Retrieve NVMe subsystem maps
GET /protocols/nvme/subsystem-maps
Retrieves NVMe subsystem maps.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
anagrpid
Related ONTAP commands
vserver nvme subsystem map show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
nsid |
string |
query |
False |
Filter by nsid |
anagrpid |
string |
query |
False |
Filter by anagrpid |
subsystem.name |
string |
query |
False |
Filter by subsystem.name |
subsystem.uuid |
string |
query |
False |
Filter by subsystem.uuid |
namespace.node.name |
string |
query |
False |
Filter by namespace.node.name |
namespace.node.uuid |
string |
query |
False |
Filter by namespace.node.uuid |
namespace.name |
string |
query |
False |
Filter by namespace.name |
namespace.uuid |
string |
query |
False |
Filter by namespace.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nvme_subsystem_map] |
"next": {
"href": "/api/resourcelink"
"records": [
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"node": {
"name": "node1",
"nsid": "00000001h",
"subsystem": {
"name": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
namespace
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.
_links |
name |
string |
The fully qualified path name of the NVMe namespace composed from the volume name, qtree name, and file name of the NVMe namespace. Valid in POST. |
node |
uuid |
string |
The unique identifier of the NVMe namespace. Valid in POST. |
subsystem
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
The unique identifier of the NVMe subsystem. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
nvme_subsystem_map
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
_links |
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h". There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
namespace |
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
subsystem |
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
