REST API reference
Retrieves the nvme subsystem hosts of an nvme subsystem
  • subsystem_maps* # related ontap commands
  • vserver nvme subsystem map show
  • vserver nvme subsystem show # learn more
  • [doc /protocols/nvme/subsystems](#docs-nvme-protocols_nvme_subsystems)
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Retrieves the NVMe subsystem hosts of an NVMe subsystem.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
  • subsystem_maps.*
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[nvme_subsystem_host]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "io_queue": {
        "count": 4,
        "depth": 32
      "nqn": "nqn.1992-01.example.com:string",
      "subsystem": {
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
_links
_links
uuid
string
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links
_links
io_queue
io_queue
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
subsystem
subsystem
nvme_subsystem_host
_links
_links
io_queue
io_queue
nqn
string
subsystem
subsystem
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
