REST API reference
Retrieves a fibre channel protocol service
learn more
  • [doc /protocols/san/fcp/services](#docs-san-protocols_san_fcp_services)
GET /protocols/san/fcp/services/{svm.uuid}
Retrieves a Fibre Channel Protocol service.
  • vserver fcp show
svm.uuid
string
path
True
The unique identifier of the SVM for which to retrieve the FC Protocol service.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
The administrative state of the FC Protocol service. The FC Protocol service can be disabled to block all FC Protocol connectivity to the SVM.
This is optional in POST and PATCH. The default setting is true (enabled) in POST.
svm
svm
target
target
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "target": {
    "name": "20:00:00:50:56:bb:b2:4b"
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
5374083
There is no Fibre Channel Protocol service for the specified SVM.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
target
name
string
The target name of the FC Protocol service. This is generated for the SVM during POST.
The FC Protocol target name is a world wide node name (WWNN).
If required, the target name can be modified using the ONTAP command line.
  • example: 20:00:00:50:56:bb:b2:4b
  • maxLength: 128
  • minLength: 1
  • readOnly: 1
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
