REST API reference
Retrieves lun maps
  • [doc /protocols/san/lun-maps](#docs-san-protocols_san_lun-maps)
learn more
GET /protocols/san/lun-maps
Retrieves LUN maps.
lun.node.name
string
query
False
Filter by lun.node.name
lun.node.uuid
string
query
False
Filter by lun.node.uuid
lun.name
string
query
False
Filter by lun.name
lun.uuid
string
query
False
Filter by lun.uuid
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
igroup.os_type
string
query
False
Filter by igroup.os_type
igroup.protocol
string
query
False
Filter by igroup.protocol
igroup.initiators
string
query
False
Filter by igroup.initiators
igroup.name
string
query
False
Filter by igroup.name
igroup.uuid
string
query
False
Filter by igroup.uuid
logical_unit_number
integer
query
False
Filter by logical_unit_number
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[lun_map]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "igroup": {
        "initiators": [
          "iqn.1998-01.com.corp.iscsi:name1"
        "name": "igroup1",
        "os_type": "string",
        "protocol": "string",
        "uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
      "logical_unit_number": 1,
      "lun": {
        "name": "/vol/volume1/qtree1/lun1",
        "node": {
          "name": "node1",
          "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
_links
_links
initiators
array[string]
The initiators that are members of the initiator group.
name
string
The name of the initiator group. Valid in POST.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.
uuid
string
The unique identifier of the initiator group. Valid in POST.
node
The LUN node.
_links
_links
name
string
The name the LUN's node.
uuid
string
The unique identifier of the LUN node.
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
_links
_links
name
string
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST.
node
node
The LUN node.
uuid
string
The unique identifier of the LUN. Valid in POST.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
_links
_links
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • example: 1
  • maxValue: 4095
  • minValue: 0
  • readCreate: 1
lun
lun
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
