Retrieve the Vscan On-Access policy configuration for an SVM
GET /protocols/vscan/{svm.uuid}/on-access-policies/{name}
Retrieves the Vscan On-Access policy configuration of an SVM.
Related ONTAP commands
vserver vscan on-access-policy show -
vserver vscan on-access-policy file-ext-to-include show -
vserver vscan on-access-policy file-ext-to-exclude show -
vserver vscan on-access-policy paths-to-exclude show
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
name  |
string  |
path  |
True  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
enabled  |
boolean  |
Status of the On-Access Vscan policy  |
mandatory  |
boolean  |
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.  |
name  |
string  |
On-Access policy ame  |
scope  |
  "name": "on-access-test",
  "scope": {
    "exclude_extensions": [
      "mp*",
      "txt"
    "exclude_paths": [
      "\\dir1\\dir2\\name",
      "\\vol\\a b",
      "\\vol\\a,b\\"
    "include_extensions": [
      "mp*",
      "txt"
    "max_file_size": 2147483648
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
scope
exclude_extensions  |
array[string]  |
List of file extensions for which scanning is not performed.  |
exclude_paths  |
array[string]  |
List of file paths for which scanning must not be performed.  |
include_extensions  |
array[string]  |
List of file extensions to be scanned.  |
max_file_size  |
integer  |
Maximum file size, in bytes, allowed for scanning.  |
only_execute_access  |
boolean  |
Scan only files opened with execute-access.  |
scan_readonly_volumes  |
boolean  |
Specifies whether or not read-only volume can be scanned.  |
scan_without_extension  |
boolean  |
Specifies whether or not files without any extension can be scanned.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
