Retrieve a SAML service provider configuration
GET /security/authentication/cluster/saml-sp
Retrieves a SAML service provider configuration.
Learn more
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
enabled |
boolean |
The SAML service provider is enabled. Valid for PATCH and GET operations only. |
host |
string |
The SAML service provider host. |
idp_uri |
string |
The identity provider (IdP) metadata location. Required for POST operations. |
"href": "/api/resourcelink"
"certificate": {
"ca": "string",
"common_name": "cluster1",
"serial_number": "1506B24A94F566BA"
"host": "string",
"idp_uri": "https://idp.example.com/FederationMetadata/2007-06/FederationMetadata.xml"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
ca |
string |
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name. |
common_name |
string |
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number. |
serial_number |
string |
Server certificate serial number. This cannot be used with the server certificate common name. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
