Retrieve key managers
GET /security/key-managers/{uuid}
Retrieves key managers.
Related ONTAP commands
security key-manager show-keystore -
security key-manager external show
Learn more
uuid |
string |
path |
True |
Key manager UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
external |
Configures external key management |
onboard |
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
"href": "/api/resourcelink"
"external": {
"client_certificate": {
"server_ca_certificates": [
"servers": [
"server": "keyserver1.com:5698",
"timeout": 60,
"username": "username"
"onboard": {
"existing_passphrase": "The cluster password of length 32-256 ASCII characters."
"scope": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
client_certificate
Client certificate
_links |
uuid |
string |
Certificate UUID |
Security certificate object reference
_links |
uuid |
string |
Certificate UUID |
key_server_readcreate
_links |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
Username credentials for connecting with the key server. |
external
client_certificate |
Client certificate |
server_ca_certificates |
array[server_ca_certificates] |
The UUIDs of the server CA certificates already installed in the cluster or SVM. The array of certificates are common for all the keyservers per SVM. |
servers |
array[key_server_readcreate] |
The set of external key servers. |
onboard
enabled |
boolean |
Is the onboard key manager enabled? |
existing_passphrase |
string |
The cluster-wide passphrase. This is not audited. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
