REST API reference
Retrieves key servers configured in an external key manager
GET /security/key-managers/{uuid}/key-servers/{server}
Retrieves key servers configured in an external key manager.
  • security key-manager external show
uuid
string
path
True
External key manager UUID
server
string
path
True
Key server configured in the key manager
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
password
string
Password credentials for connecting with the key server. This is not audited.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if records is provided.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
KMIP username credentials for connecting with the key server.
      "href": "/api/resourcelink"
  "password": "password",
  "server": "keyserver1.com:5698",
  "timeout": 60,
  "username": "username"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
records
_links
_links
password
string
server
string
timeout
integer
username
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
