Retrieve key managers
GET /security/key-managers
Retrieves key managers.
Related ONTAP commands
security key-manager show-keystore -
security key-manager external show
Learn more
onboard.enabled  |
boolean  |
query  |
False  |
Filter by onboard.enabled  |
external.server_ca_certificates.uuid  |
string  |
query  |
False  |
Filter by external.server_ca_certificates.uuid  |
external.client_certificate.uuid  |
string  |
query  |
False  |
Filter by external.client_certificate.uuid  |
external.servers.server  |
string  |
query  |
False  |
Filter by external.servers.server  |
external.servers.timeout  |
integer  |
query  |
False  |
Filter by external.servers.timeout  |
external.servers.username  |
string  |
query  |
False  |
Filter by external.servers.username  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
scope  |
string  |
query  |
False  |
Filter by scope  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[security_key_manager]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "external": {
        "client_certificate": {
        "server_ca_certificates": [
        "servers": [
            "server": "keyserver1.com:5698",
            "timeout": 60,
            "username": "username"
      "onboard": {
        "existing_passphrase": "The cluster password of length 32-256 ASCII characters."
      "scope": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
client_certificate
Client certificate
_links  |
uuid  |
string  |
Certificate UUID  |
Security certificate object reference
_links  |
uuid  |
string  |
Certificate UUID  |
key_server_readcreate
_links  |
server  |
string  |
External key server for key management. If no port is provided, a default port of 5696 is used.  |
timeout  |
integer  |
I/O timeout in seconds for communicating with the key server.  |
username  |
string  |
Username credentials for connecting with the key server.  |
external
Configures external key management
client_certificate  |
Client certificate  |
server_ca_certificates  |
array[server_ca_certificates]  |
The UUIDs of the server CA certificates already installed in the cluster or SVM. The array of certificates are common for all the keyservers per SVM.  |
servers  |
array[key_server_readcreate]  |
The set of external key servers.  |
onboard
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.
enabled  |
boolean  |
Is the onboard key manager enabled?  |
existing_passphrase  |
string  |
The cluster-wide passphrase. This is not audited.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
_links  |
external  |
Configures external key management  |
onboard  |
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.  |
scope  |
string  |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".  |
svm  |
SVM, applies only to SVM-scoped objects.  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
