REST API reference
Retrieves a specific snapmirror policy
get "/api/snapmirror/policies/567aaac0-f863-11e8-a666-0050568e12c2"
<br/> # learn more * [doc /snapmirror/policies](#docs-snapmirror-snapmirror_policies)
GET /snapmirror/policies/{uuid}
Retrieves a specific SnapMirror policy.
Example
GET "/api/snapmirror/policies/567aaac0-f863-11e8-a666-0050568e12c2"
uuid
string
path
True
Policy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
Comment associated with the policy.
identity_preservation
string
Specifies which configuration of the source SVM is replicated to destination. This field is applicable only for SVM data protection and async policies.
name
string
network_compression_enabled
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to async policies.
retention
array[snapmirror_policy_rule]
Policy on Snapshot copy retention. This is applicable only to async policies.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
sync_common_snapshot_schedule
Schedule used to create common Snapshot copies for synchronous relationships.
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
The schedule used to update asynchronous relationships.
type
string
uuid
string
      "href": "/api/resourcelink"
  "comment": "string",
  "identity_preservation": "string",
  "name": "MirrorAndVault",
  "retention": [
      "count": 7,
      "creation_schedule": {
        "name": "weekly",
      "label": "hourly",
      "prefix": "string"
  "scope": "string",
  "svm": {
    "name": "svm1",
  "sync_common_snapshot_schedule": {
    "name": "weekly",
  "sync_type": "string",
  "throttle": 0,
  "transfer_schedule": {
    "name": "weekly",
  "type": "string",
Status: Default
ONTAP Error Response codes
Error code Description
13303842
Invalid SnapMirror policy type.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
SnapMirror policy rule for retention.
count
integer
Number of Snapshot copies to be kept for retention.
creation_schedule
creation_schedule
label
string
Snapshot copy label
prefix
string
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
